Question about Electronics - Others
Memory card error due to moisture on card
I have a Memory card error due to moisture on my memory card. I have tried CardRecovery and ZAR softwares to no avail. They report no data on card and that all the sectors are bad. It is my girlfriend's, daughter's memory card, she had a couple hundred pictures on it and had not saved them elsewhere. Dog picked up card when we changed cards. No outside damage but apparently the dog's saliva ruined the card. Any suggestions are greatly appreciated.
Sincerely,
Kent
    Sniper:
  • 55 Answers
What kind of memory card is it? I think this may help... I accidentally left my USB in my pocket while in the laundry and when it was dried, it worked. Try putting it in front of the sun or find a hot spot and let all the water evaporate. This process may take a week.
Hope this helped!
Nicholas
Posted on Jan 26, 2008
6ya staff
SOURCE:
Hi my blackberry 8520 says my memory card can not be accessed due to fatal errors. pls what can i do???
Hi there. Have you tried a different memory card? With the one that is giving you an error I would try formatting it on your computer and see if this helps. when you connect the card to the computer you should right click on it and then select format. Make sure it is formatted as FAT or FAT32 and then try it again in your phone.
Sep 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
I purchased a prepaid phone today and when i put my memory card in it didnt work. I reformated the card and now it is empty of all pictures. WHAT DO I DO?!
Unfortunately there isn't much you can do. When you "reformat" something such as a memory card or hard drive, you are actually erasing all the data. Once it's gone, it's gone. Sorry I don't have better news for you.
Mar 01, 2011 | Cameras
Memory stick with loads of data on it but computeer says it needs fromatting before i can use it. This will erase data what can i do please?
search google for ZAR (zero assumption recovery) software, download for free and use unlicensed test version. install to pc, put your card into your pc's card reader and run ZAR, follow steps given to copy your data to hdd, it will take some time to read and save the memory stick. hope to helped you
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 20, 2011 | Computers & Internet
Memory Card locked
this solution is from a another website about card error... i dunno if this will help fix ur problem but i hope this will give u idea how to fix it... okay.. tell me if this works, coz a lot of people were encountering the same prob as u.. thank God i havent encounter this error...good luck..
Troubleshoot:
Memory card is used by digital camera to store the photos it takes. Popular memory cards include SD card, CF card, xD-Picture card and Memory stick. For some reasons, memory card may get damaged on power shortage, or removal of memory card on picture shooting or viewing, or other various and unknown reasons. Usually, you will see error message like "memory card error", "card locked", "card error", or an error code on your camera screen and the valuable pictures on the memory card could disappear and be lost. Some cases, your camera or Windows may prompt you to re-format the memory card and refuse to take new pictures or view old pictures.
Solution:
Once you have your memory card damaged, it is highly recommended to stop further operations on the memory card (e.g. taking new pictures, or delete, format the memory card). Data recovery software like "CardRecovery" is able to recover the lost pictures in most cases.
First, you need to confirm your memory card can appear as a drive letter in "My Computer", which will allow recovery software to access and recover the lost photos. You may try to connect your digital camera to your computer, if a new drive letter appears in "My Computer", it is OK. Otherwise, you need to prepare a USB card reader. There are many card readers available in market (e.g. SanDisk and Kingston). You can buy one from Amazon or BestBuy.
Then, you may download and install CardRecovery to your computer. Launch it from Start Menu -> Programs -> CardRecovery. You select the drive letter of your memory card, and destination folder for save the recovered files. CardRecovery will scan your memory card and locate the recoverable pictures. The process is quick and easy. Usually it takes less than 15 minutes.
Can I re-use the corrupted memory card?
For data protection, CardRecovery performs read only operation on your memory card and it does not change the data on the memory card, so it does not repair or fix the memory card. If you need, AFTER you have recovered your lost photos from the card, you may try to format the memory card before re-use. It is suggested to perform enough read/write test before using it again to take new pictures. If you are worrying that the memory card is unstable and may cause further data loss, purchase and use a new memory card. Your valuable and irreplaceable photos are more important than memory card. Memory card is very cheap. A new 2GB SD, CF or xD card is less than $10.
credits: www.cardrecovery.com
Sep 13, 2009 | Canon PowerShot A75 Digital Camera
Memory card error
from cardrecovery.com..
alot of people encounters this prob... hope this will help u.. but im not sure if it will fix the problem..
but again 9sure u already did this) check the slide or card rotection of ur card, then check also the slot on the cam where u put the card -- there was a thread about this , like u can pick it with papaer clips blah blah not sure how he did it, it worked for him but i dont advise it bec pis are very sensitive so just dont do it...
here is it... solution from cardrecovery
Troubleshoot:
Solution:
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
Memory card locked
this is from cardrecovery.com... whew a lot of people get this error... hope all of u resolves this..
but before u truobleshoot for recovery of pictures, check first the slide on your memory card (card protection) slide it both ways and check it... someone advices from a thread to use paper clips to pick the slot of the cam where u put the card, it work for him but i think its not a good idea coz it may damage the slot.. okay.. if there is still an error u can bring it to a tech person (canon support service) or just try to recover ur files...
Troubleshoot:
Solution:
Sep 12, 2009 | Canon PowerShot A470 Digital Camera
Diappearing Pictures
If the photos were transferred from the internal memory of your camera to your card, you may be able to retrieve them with special software (even after the card is formatted).
I've had corrupted memory cards in the past and had some success with software like CardRecovery. This one has a free trial:
http://www.cardrecovery.com/download.asp
Mar 31, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
Memory card formatted in error
Once the memory card is formatted, the files saved or pictures will be deleted and there is no way to retrieve the images.
I would advise that you transfer the pictures first to your PC before formatting the memory card.
Sep 25, 2007 | Cameras
Electronics - Others Logo
56 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
