RCA Television Model 32V524t
I have a RCA Television and the screen went blank, no sound, on light stay on and can not be put out unless the ac plug is disconnected. All other functions appear dead.
  • 152 Answers
There is a huge posibility that the electricity wasnt stable and burned your tv... ill try to find a way so you can check if it got burned...
by the way.. how old is the tv?
and when you mean blank.. blank as in black.. right?
does it shows any kind of signs of being on when you turn it on? like lighting up a led?
Posted on Jan 18, 2008
  • Asdrubal Perez Jan 18, 2008
    by the way.. i suposed that when this happened, you where watching tv and suddenly it went blank...
    did it make any sound or smell like something?
    i still think that some transistor got busted.. and it would be dangerous for you tu fix it, since tvs always carry high voltages within and even if they are off they can charge you with lots of voltage... so be carefull..
    i also found this:
    its the user manual..
    still.. i am 99% secure that some high voltage went in to the tv and killed it.. so i recommend you to send it to a qualified repairman before you could get hurt and this wont be an easy task at all..
    even from where i am it will be really hard and waste lots of time to walk you througt to see if we could fix the problem..
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
Tv wont turn on, red flashing light
Apr 11, 2009 | RCA 32V524T TV
Jul 20, 2008 | RCA 20F511T TV
ca you tell me what is exactly trouble in your television!?
Jun 22, 2008 | RCA 32V524T TV
Sounds like a bad horizontal transistor and flyback transformer . Do you know how to unsolder and or solder ? If so you might have a chance . If no the avg. to get repaired is around $90.00 to $130.00 so shop around as some shops will charge more . The parts you could buy your self for around $30.00 to 40.00 . Good luck and if you think you could fix let me know and see if i can get you part numbers .
Mar 15, 2008 | RCA 32V524T TV
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Mar 14, 2008 | RCA 32V524T TV
On light stays on and can not be put out. no other action takes place such as a lit screen or sound.
bad panel its done u can unplug re try after 45 min is i clean alot dust aorund it heat can build up gotta have good power supplies with these monster power strips with clean power to make power stable these tvs so touchy on vlatge going up and down
Jan 18, 2008 | RCA 32V524T TV
Tv went blank
Does the timer/stand-by light blink at all? If so, count how many times it does. It will usually be in intervals. If it isn't blinking, and you have nothing on the screen, you might have a problem with the "G" Board, part # A1316499A.
Dec 16, 2007 | Sony KP-61V90 61" Rear Projection...
Rca 32v524t chassis-atc010a
replaced,off/on vol,up and down,and channel up and down.
Nov 21, 2007 | RCA 32V524T TV
RCA 32V524T- Blown fuse?
If you blew the fuse, the TV would do absolutely nothing - no lights, no sounds, nothing. It could be that the loud zapping noise you heard was the high voltage transformer arcing or shorting out. This could have caused the horizontal output transistor to short, and the set will not start as a result. You should have the set serviced by a qualified tech.
Sep 01, 2007 | RCA 32V524T TV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
