Question about RCA HD61LPW165 61" Projection HDTV
How to replace the color wheel on a RCA DLP
My RCA HD61LPW165 XY7 has a bad buzzy noise and the color changes and goes out then it shuts down. I am sure it is the color wheel but no one seems to have the part 267888 i did find one place that will rebuild it. my problem is i cant seem to find any info on how to take it replace it. and help would be appreciated
  • 3 more comments
  • Tazman62 Feb 27, 2008
    Thanks that worked great and was easy after i figured out that it came out from the top inside an not the bottom from the back.
    Replaced the color wheel and now the HV Ballist has a diode that is buzzing and glowing think it is breaking down any ideals ??
  • acm53 Jul 13, 2008
    On the 61" RCA DLP, how do you disconnect the copper ribbon on the old color wheel? It doesn't seem to pull out. I don't want to mess up the connection.
  • beyond666 Nov 29, 2008
    I have an RCA Scenium which was bought in Feb of 2004, it's a 61 inch DLP. The model number is HDLP61W151YX1. The problem I'm having is that the color wheel is making a lot of noise and now the screen flashes white burst os snow every minute or so, it's very quickly but as the TV stays on the longer the burst get more frequent. I know it's not the bulb because I've already changed the bulb last year, and when it's the bulb you get no picture at all, so it must be the color wheel. I know where I can purchase a new color wheel but, I need instructions on how to replace the old with the new, can you help me in that respect. If you can please e-mail me at your earliest opportunity. Thank you very much. David
  • nte8 Dec 05, 2008
    loud buzzing sound as well as color fading with white flashes
  • chucky216 Feb 09, 2009
    rca hd44lpw62 44 inch hdtv
  • 3 Answers
RCA DLP color wheel replacment is most efficiently done from the behind the screen, not the back panels where the guts of the DLP are located.
From there you do not need to remove anything but the color wheel and disconnect the two wires.
If you want to see pictures, email me and I can send you pictures. email: graphguy@gmail.com
Posted on Jul 27, 2008
  • 579 Answers
There isn't anything to tricky about replacing th ecolor wheel if you are mechanically inclined at all. Have to take out the light engine and all, but no carefull alignments or anything.
Try these sources for parts
partstore.com
andrewselectronics.com
tritronics.com
Posted on Jan 18, 2008
  • 298 Answers
62" RCA dlp loses color
If you hear any winding, whirling or screeching noise (Color Wheel symptoms)
If there is any vibrations in the TV (Color Wheel symptoms) you would need to change the color wheel.
Apr 15, 2010 | RCA HD61LPW165 61" Projection HDTV
The color apprears to be in like 3d I was told it was teh color wheel but its not making any noises
It's the color wheel. The color wheel does not need to make noises for the color wheel to be bad. Sometimes it can spin slower or malfunction all together and you'll get intermittent shadows or color splotches with messed up skin tones.
Feb 05, 2010 | RCA HD61LPW165 61" Projection HDTV
My RCA 61" DLp has lost its red hue.
If its not the color wheel its the Light engine! Call Encompass Parts 1-800-638-3328
Dec 17, 2009 | RCA HD61LPW165 61" Projection HDTV
Instructions on How to change an RCA Color Wheel
You can get help at;
http://servicemanuals.vstore.ca/
They will charge for manuals but they also give on-line tech support free!
Apr 06, 2009 | RCA HD61LPW165 61" Projection HDTV
Loud squealing noise first 5 minutes after tv is turned on
Sounds like the color wheel. It's the only moving part in most DLP's and the bearings can go bad. If it manages to get up to speed the picture may look normal. One temporary solution may be to let it run a few minutes, then turn the set off for 10 minutes, then turn back on. When my color wheel was going bad that would often quieten it down. For the rest of the day, try to leave the set on, especially if you're only going to be away from the TV for short periods. You can turn off your cable or satellite box but leave the set on and you won't have to go through the hassle of trying to quieten down the color wheel until the next cold start. Of course the best solution is to replace the color wheel which even with a rebuilt unit won't be cheap if your warranty is expired.
Nov 02, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HD61LPW165 61" Projection HDTV Logo
8,643 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
