Question about Toshiba Satellite 1905-S301 Notebook
On off switch
Once the switch is depressed the laptop comes on then shuts right down again.
  • malc510 Jan 19, 2008
    yes it is
    Genius:
  • 1,003 Answers
IS THIS COMPUTER SHUTTING DOWN EVEN WHEN IT PLUGGED UP TO AC ADAPTER
Posted on Jan 18, 2008
6ya staff
SOURCE:
Can't turn on Dell Inspiron 1501
dear sir , acutully your dell laptop is in hibernation mode, and is not coming back
you can try following:
1. remove batter plug directly and try to switch it on without battry.
or
2.press power switch for 13 sec continusly and once it shuts down , switch on it again
this will definatly help you
thanks
Dec 11, 2007 | Computers & Internet
HI GEAR BOX WILL NOT KICK DOWN C270 CDI 02 THANKS BUT ALL THE GEAR WORK OK EVEN THE TRIP
first check is the kick down switch working or not, as a first step, get in to the driver seat, don't switch on or start, press accelerator paddle slowly til end then depress and listen is it make a click sound or not, if not kick down switch could be faulty, this information for you to understand how the kick down switch working, when you drive the car did you depress and check the kick down working or not same as you did now? once again drive car and fully depress accelerator and check if not working you must get it in to the Mercedes workshop for right diagnose possibly faulty kick down switch in accelerator paddle, is this information helped you?
Oct 19, 2010 | 2002 Mercedes-Benz C-Class
Laptop will not switch off untill press switch button of laptop
you have a corrupted software try to format and reinstall it again, most corrupted system comes from improper shut down sometimes during installation your CD or DVD rom is defective although it is reading and seams working fine try to install your system using other rom drive
Sep 18, 2009 | Acer Aspire 5920-6727 Notebook
Dv6700 hp laptop wont power on
This is a dumb question i'm going to ask but is the power cord plugged in. Mine recently killed over. Come to find out it was the battery pack, which was fully charged, just didnt work anymore.
Aug 03, 2009 | HP ProCurve Switch 2650
What is the EE message on the DuoTherm Comfort Control Center?
It means that an error has occurred. If you have a 4 button comfort control. Follow these steps to reset:
To initiate a RESET, do the following in the order
listed:
1) Turn control on to ensure annunciator data and light are present. If data and light are present, continue to next step. Depress MODE switch to activate annunciator light.
Simultaneously depress the bottom two buttons (temperature UP and DOWN) and hold.
While holding these buttons down, depress the MODE button once and release.
Release the two buttons previously held down. Depress the MODE button once again.
At this time the light should extinguish, and the mode should register “OFF”. If not, repeat these steps.
Retest system ensuring that all functions are present
and operational.
If you have the five button comfort control. Turn the unit off and hold down the mode and zone buttons together. While holding them down, turn the thermostat back on. Hold the buttons down until an FF appears on the screen. Release the buttons and the display should return to normal. If not, try it again.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Toshiba Satellite A55-S306 doesn't come out of hybernation
Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
Laptop auto shuts off - will not come back on
have you checked the power coming fine. If you were working on battery mode it cud be coz of battery issue...
remove the battery & switch on the laptop in power mode.
Dec 03, 2008 | Acer Aspire 5050 Notebook
Laptop beeped once as it shut down
Ya its a computer they are built to fail =). 1 beep is usually a normal sign. when you start hearing more then 1 beep then I might worry.
If you found this helpful I hope you will rate accordingly. If you have anything else ever in the future you can use the ask me feature at
www.fixya.com/users/leethedeuce
Thanks,
Lee
Jun 21, 2008 | Toshiba Satellite A135 Notebook
E005
Hello bud,easy problem just replace your fuser cleaning web,and reset the counter.
Oct 24, 2007 | Canon NP 6050 Copier
Toshiba Satellite 1905-S301 Notebook Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
