Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer Fisher paykel
Sensing is not working
  • Anonymous Feb 26, 2008
    I have a Fisher Paykel dryer and from the first couple of months there has been a problem with black streaks on the clothes. I have had the drum replaced and also the glides replace 3 times. Again, I am waiting for the repairman to arrive. FP at this point should be replacing my dryer with a new one since from the very beginning of owning this machines there has been problems.
  • 92 Answers
The biggist problem with dryers and drying is the outside vent being plugged. next thing is it gas or electric. electric i would think cycling thermostat. gas would be coils or thermostat. this is asuming you do have heat
Posted on Jan 20, 2008
How to remove a door switch from a fisher and paykel ED55 dryer
see the video and use the common sense. God bless you
Sep 28, 2012 | Fisher and Paykel Dryers
Fisher and paykel won't let water in but just sensing water level non-stop
Any switch the same size will work there fine,
It must have the three pins,com, nc, no on the switch.
May 08, 2012 | Fisher and Paykel Fisher & Paykel Washer
Dryer gets a little warm, but clothes are not drying at all as if the heating source is not activating and it continues to sense the dryness until it eventually turns off.
Check the lint filter and all the duct work on the dryer for lint. When you get excessive lint buildup, it will prolong the drying time.
Dec 31, 2010 | Fisher and Paykel DGIX2 Dryer
My dryer is a top loading Fisher and Paykel and it has started squeaking.
It could be bearing or guide in the drum.Go to This forum will work you through your problem
Sep 21, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer not providing any heat during cycle
Go to Check posts on "Heaters" in this forum will work you through your problem
Jun 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Clothes not dry
check your dryer venting from the machine to the outside vent,if they are plugged it will not dry properly,then make sure you have good air flow to vent on machine,if not dismantle and clean lint from inside machine,these are inexpensive fixes,then it could be a cycling switch or the humidity sensor bar that needs replace
Jan 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Wont start. Extra dry light on and cool down light on.
Fault #3 Drum Stalled; unable to move.
  1. Check drum movement mechanisms: belt, motor and motor harness (if motor moves drum slightly, treat as fault #2)
  2. Replace the motor control module.
  3. Replace the motor.
Fault #2 Drum Gap Cannot be Located
  1. Ensure sensor module is correctly located and clipped in.
  2. Replace the lens on the sensor module.
  3. Replace the sensor module.
  4. Remove Top Deck and clean the sensing bumps on the outside of the drum end.
  5. Replace the drum.
May 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
My fisher paykel DEGX1 won't heat up. everything else works fine.
If you have the same I do then it's the circuit breaker on the heating element. You have to take the front of the dryer off: Two screws on the top under the caps. Then lift the top alittle and you'll see the two screws on the front top sheet metal. The front then can be removed by pulling each side out and forward. The orange button is all the way at the bottom. Push and you'll hear it click.
Mar 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
195 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
