HP Deskjet 830c
My printer jammed and then it needed to be "reset" and all I remember from the last time this happened was that you had to do some sort of code by pressing the 2 buttons on the front of the printer. Until I can figure out this code thing it is going to keep spitting out slews and slews of paper that it is printing chinese on. (the first line)
pls help b/f my husband launches it across the room.
  • 91 Answers
Have you tried removing all its plugs and then pugging it in again, this should reset most stanard printers?
Posted on Jan 18, 2008
Im looking for a driver for Hp deskjet 825c for windows 7 in south africa
Use the Deskjet 830C/832C drivers. I have a Deskjet 825C and the Deskjet 830C/832C works fine on my Windows 7 64 bit OS. It will work with the 32 bit version as well.
Previously I had Windows Vista installed and found the Deskjet 830C driver worked ok with it as well.
1. Start, Control Panel, Devices and Printers
2. Click Add a printer
3. Click add a local printer
4. Selct Use an existing port
5. In the drop down list select USB001 or 002 or 003, which ever appears. It should say "(Virtual printer port for USB)"
6. click next
7. On the install the printer driver screen under manufacturer select HP
8. Under printers select HP deksjet 830C/832C
9. Click Next
10. If prompted for Which version of the driver do you want to use?" select "Use the driver that is currently installed." and click next
11.Type a name for the printer int the text box for printer name:
12. Click next
13. If you want other computers on your network to be able to share this printer select "Share this printer..." and click next.
14. click print a test page.
15. Click finish.
Download Driver...... HP Deskjet 825c Printer Drivers
Read More help... HP Printer Support
Aug 18, 2014 | HP DeskJet 825c InkJet Printer
I cannot get my HP deskjet 830C to print in color. i just put new cartridges.
First of all I would recommend running a cleaning cycle from your printer. If this still fails to solve your problem please take the following steps:
- Remove the cartridge from the printer and stand it on a hot wet cloth or kitchen towel with the print head touching the cloth.
- Leave for 30-60 seconds and this should remove any ink that may be blocking the nozzle. The cloth will begin to soak up ink from within the cartridge.
- Reinstall and run one more head cleaning cycle which should resolve your problem.
If it still doesn't print correctly then sadly it is likely that the cartridge is faulty.
Sep 16, 2012 | Shop For Battery Hp Deskjet 830C Printer...
HP Deskjet D4100 1) The arrow pointing down near the power switch is flashing. Printer will not print. 2) The printer goes "offline" Paper is not jammed, have unplugged/plugged. rebooted numerous...
First, here is a link for the troubleshooting your printer:
I always go the the manufacturer website to download drivers. I also just had a similar problem on our printer at church. Two people looked and looked after pulling a jammed paper out of the printer. I looked a few times, opened the 2 back doors, the front door, removed the paper trays and looked, opened the side door, and looked again. Each time the printer said jam. I got a flashlight and looked everywhere again, nothing. Still said jam. I looked one more time in above where the paper trays go, and under a piece of plastic just barely visible at just the right angle was a tiny scrap of paper, not much bigger than a quarter. I managed to get it out and all works fine. Possibly you may have something like this going on?
Dec 22, 2017 | HP Deskjet D4100 series
HP Deskjet F2290, unable to print after paper jam
just On it twice and then off,, check you have removed paper jam and installed drivers.. aall
Sep 28, 2009 | Office Equipment & Supplies
Vista driver for HP 825C printer
What a great idea Marc! It worked!
"Hi, I just resolved the same problem. I installed from the VISTA preinstalllation list of printers the driver and files for the HP 830C/832C printer. The "install a new printer" on the control panel-printers page shows it on the list. After installation I went to the 830C/832C printer properties and selected it to be located in the USB virtual printer port where my 825C was connected (select any USB it does not matter). Now the VISTA believes that you have a 830C/832C printer on the USB and prints perfectly with this setup on the 825C.
Bye, Marc
Feb 16, 2008 | Microsoft Windows Vista Ultimate Edition
Paper jam
Dear taytay I describe what exactly happened. When a paper stucked in your printer, you have picked it back from the same way very pressurly, that is wrong. Next time, when it happens again, Open the back door of the printer and turn out the paper from there. Only mechanic can solve your problem, there is a mechanical error.
Sep 25, 2007 | HP Deskjet D1341 InkJet Printer
Printer won´t work
hp provides a line of wireless printers and sometime printer won't print with here is what you may have to do in order to het this fixed
1. make sure your wireless password
2. uninstall the printer software and reinstall it once again ( make sure you configure the router with wireless router) for more assistance contact with hp Printer Tech Support
3.. now type the right password and try to print it
ihope this may help you
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
