Question about Garmin Nuvi 660 GPS Receiver
Nuvi 660 My 660 will only turn on and show "Garmin Nuvi". It won't go any further. If it's not plugged up it will turn off after showing the Garmin Nuvi screen. I tried resetting and charging ovenight to no avail. Can you help.
  • 4 more comments
  • barcenillaj Nov 18, 2008
    garmin nuvi 660 will no longer power on, even if i've tried charging it.
  • Anonymous Nov 23, 2008
    same problem
  • moon_candy Nov 25, 2008
    I am in the same boat, but mine has been doing this since summer. I purchased it last November. Garmin was to have emailed the cure, but I have not received the email since 2 weeks ago. They did tell me to press the lower right corner, but nothing happened
  • trumpetmike Dec 08, 2008
    Mu Garmin 660 wont boot. It either shows the Garmin screen and loading maps and won't go any further, or it just shuts off
  • Anonymous Mar 13, 2014
    My Nuvi 50LM frozen on startuup logo page and will not go any further... have tried master reset to no avail
  • Anonymous Mar 19, 2014
    When I turn on my Garmin Nuvi 40 it shows all addresses from Sydney not my home address
  • 35 Answers
    Scholar:
  • 40 Answers
In case it is a software problem try this and see if it will fix it....Try this and see if it fixes your problem...follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Posted on Jan 19, 2009
6ya staff
SOURCE:
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
Jan 05, 2016 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
When I plug in the power cord it doesn't show that it is charging. All of the maps and setting are running fine. When I power it off and power is on again with the cord attached it will not charge. I...
That simply shows that the power adapter/cord is bad. To confirm it, all you need to do is to borrow another charger then plug your garmin nuvi on it to see if it charges, if it charges, then it means what you have to replace is your charger. The former battery is not bad since it can power on and off the gps.
Solution, Get a new charger for your garmin nuvi 660 gps receiver. Am very well convinced that,replacing the charger will do the job.
Hope this piece of information helped.
Dec 22, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 shutting off
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
New Garmin Nuvi 660 gps
Page 2 of your manual shows you that the plug goes into the bottom of the GPS unit. Turn it over and you'll see a slot for the plug.
Apr 21, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660
You will have to send it back to Garmin showing proof of purchase. Garmin will clear the PIN.
Jan 28, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
Low Battery
Recharge the battery or plug it into your car cigarette lighter and turn the unit on.
Jan 06, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 MP3 files
No program , your 660 read only MP3 , but did you try with WINDOWS it should work nicely.
Contatc GARMIN and mentionned if you can transfert with MAC.
Best regards
Jan 01, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
655 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
