Question about Sony MegaStorage CDP-CX355 300-Disc CD Changer
Turntable is wacky
The turntable continued to spin around and the buttons would not work to select a cd. I turned it off and back on and it stopped spinning and the door opened. A "table error" message appeared. I removed our 125 CDs which were all in one area of the turntable. It holds 300 CDs so a large section of the turntable was empty. Weight problem or balance off, perhaps? Anyway, if you have a suggestion I would greatly appreciate it. Thank you in advance.
  • Anonymous Feb 16, 2009
    Same problem, however, cannot move discs around because once it stops and says "Table Error" nothing works
  • wmhm May 23, 2009
    Turntable spins left then right then left then right. After a few cycles it reads table error. I have cleared the memory and emptied all CD's and still nothing, just keeps spinning and reading table error.
  • 36 Answers
Try loading half your discs on one side of the turntable and the other half on the other side and see if that solves it.
Posted on Jan 26, 2008
6ya staff
SOURCE:
How to fix a Sony 5-disc player that will continue to spin and not stop at any disc slot
There are opto's around the edge of the carousel so the machine can count it's position, maybe these are at fault
Sep 30, 2014 | Sony CDP-CE375 5-Disc CD Changer
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
My 1015 will selects the same disc, then places it on the turntable. Turntable does not spin. The arm the picks the cd and places it back into it's slot. This happens continuously and the digital display...
There is most likely a problem with your K7 switch acuator. I have these in stock, and can help verify this with you over the phone. Please email me and I'll give you my phone number, [email protected]
Mar 06, 2011 | Wurlitzer Jukebox 1015 One More Time...
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Turntable won't spin
you need to open the under neth there is a belt that turns the turntabel one it could be the belt broken 2 it is slipping cheers peter
Apr 05, 2009 | Philco (R) Classic Turntable CD Shelf...
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
TTX1 went wacky
These are drive issues. More than likely one of the drive IC's failed. This will have to be repaired professionally.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Nov 24, 2008 | Numark TTX1 Turntable
Help
Lift up the platter underneath should be a belt (black rubberband) on the platter. Once you find it leave it there put the platter back on, pad off. With the player off put the belt over the brass motor spindle.
Dec 21, 2007 | Gem Sound DJ-2100 Turntable
Sony MegaStorage CDP-CX355 300-Disc CD Changer Logo
659 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
