Question about Dryers
Dial/heat problems Only a few dial positions work and there is no heat. Timed dry will not work except at the 10 min touch-up point and the only other dial position that works is the wrinkle guard position. Dryer will not work in any other dial position and there is no heat when it does work. Could this be one of the 2 fuses the info sticker notes? -Thankyou
  • 833 Answers
First, check your circuit breakers. If you are in North America, there are two linked breakers with a 30-50 amp rating. Turn them both off and then back on to reset them. I doubt there are fuses in the dryer. Next, is the motor running and the timer advancing? If not, there are issues there. If still no function, I'm going to guess at the timer as the culprit since it is working intermittently. Oh, and check to see if any wiring to the appliance is burned or damaged, including junction boxes.
Posted on Jan 19, 2008
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
I have a CDA ci992 with no instruction manual. I cannot get it to JUST dry. I just need to know which setting to put it on. Any chance you can help? I've tried searching for an instruction manual...
Lisa set the time required on the Drying time control right hand side for high temperature up to 130 mins max and left hand side for low temperature up to 90 mins max. Now set the washer timed dial to the drying emblem (3 vertical wavy lines) next to position 8, then finally you need to push in all 4 control buttons on the left of the thermostat. It should now work according to my wife. Dave
Sep 02, 2011 | CDA CI592 Front Load All-in-One Washer /...
Dryer making clicking noise when running. Heat no longer working. Gets "stuck" in a cycle continues running and dial not moving.
Based on symptoms, this is a gas dryer. The clicking that you hear is the solenoid opening so that gas can flow and be lit. Except that gas isn't flowing, or the igniter is burned out (if or pilot is blown out if so equipped).
It is normal for the dial not to move unless it is in a timed dry mode (like air or freshen mode) because the moisture level of the clothes is not changing.
Jun 13, 2010 | Kenmore 63942 Dryer
The timed dry cycle sometimes does not turn off;
If it continues running beyond the cycle point it probably is no longer producing heat and just tumbling. Eventually there is a heat sensor that is triggered. Mine does the same thing. It is likely the result of the timer going bad, though immediaely not a necessity to fix, in the long haul it will save you utilities.
Dec 07, 2009 | Frigidaire FSE748GF Dryer
Takes for ever to dry cloths
Remove the connecting vent from the rear of the dryer. Do a timed load a 50 minutes. If it is dry, clean out the connecting vent and the wall vent.
Jun 27, 2009 | GE Dryers
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
