Question about Aiptek A-HD 720P Flash Media Camcorder
Using Nightmode?? I want to film at night when there is no light. My camera does not turn its light on to record in the dark. It only flashes when taking a picture. Ive read the manual many times. How do i turn the light on?
  • ramon_batist Jun 28, 2008
    I got an Aiptek HD 1080P 30 FPS / 720P 60 FPS and when I try to make a movie at night the flash doesn't turn on... Only when I take a picture. What do I have to do ?
  • 3 Answers
The light is a flash and not meant for constant lighting. night shot is an inhanced mode for low light condition and has nothing to do with the flash
Posted on Jan 28, 2008
Buy an IR light and tape it to the dang thing. Problem solved.
Posted on Feb 12, 2009
When you purchased your camera you were probably told as i was that it could take take low light and no light video. This is incorrect. While it can take low light video, and quite well i must say. It only sees IR lights it will NOT work with an IR emitter as it will only see the reflections of the light off of various surfaces. To use IR as a light source it must be modified.
Posted on Apr 20, 2011
  • 37 Answers
Unfortunately there is no IR light (infrared) on the Aiptek A-HD, THis is a disability for me too, BUT! you can mod it to work in the night, I'm currently working on that.
Posted on Sep 23, 2008
Flash is not working
Night mode? As a professional I can set a camera to shoot at night by the settings thats why we dont use point and shoot cameras
go buy a Nikon D90, or D3100 and set the modes for night shooting
good luck.
Feb 15, 2012 | Nikon Cameras
How do you record in dark areas
Turn on the flash. Or the lights. And turn your camera into night mode.
Jun 23, 2011 | Cameras
Is there a way to turn off the flash?
The flash is automatic, you cannot control the flash. But you can put some black tape over the flash if you really don't want flash. Remember though, if the camera meter decides flash is needed, then your pictures could turn out dark/underexposed by covering the flash.
The manual can be found here: http://www.olympus-europa.com/consumer/208_manuals.cfm?prodID=P_N1246352
The manual says use 100, 200 or 400 iso films.
Maybe try high iso film like 800 iso or 1600 iso, best to try this out ahead of time to make sure you are satisfied with the results. The high iso films need less light so should perform better without flash, but the camera may not be able to rate these films correctly, trial and error is definitely required.
Oct 22, 2010 | Olympus TRIP AF 60 35mm Film Camera
How to make night photo canon 1000d but the image to be frozen?
If it's not too dark, you can try setting the ISO to 1600 or even 3200. The downside is, you'll got image noise at higher ISO (sensitivity of sensor/film).
The other alternative is using the flash. If you need to increase shutter speed beyond the capabilities of the on-camera flash in order to 'freeze' the moving subject, then use an external flash unit and set it on high speed sync.
Mar 13, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Does not record in doors or in low light. very dark display
It sounds like you may have the the camera in manual mode or that the Iris may be turned down. I am not sure if you model has an Iris control so make sure it is not in manual mode.
Dec 05, 2009 | JVC GR-D270 Mini DV Digital Camcorder
Pictures come out dark when we take at night or in a dark area...even when flash on
It might depend on what distance you expect the flash to travel in order to light the subject. How many times havbe you benn to outdoor cocerts and seen flashes going off Many of those pics are goin to be dark because the flash is unlikely to reach that distance to be effective and the only light available to the sensor is the ambient light.
You need to observe what settings the camera reports like F numbers and speed numbers 1/30 1/60 at 1/60 and below the flash is activated and the aperture might be F16 the rule of thumb is higher the number smaller the hole, which with flash this setting would be ok
if it goes to F4 5 or even 8 it may be too restictive and cause under exposure.
The ISO setting is also helpful to understand here to The ISO is like the old film speed number ASA 100 daylight film ASA 400 is more sensitive to low light so change your ISO (ASA) setting to a higher number and see if that helps you take a better picture
Cheers
Jul 30, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
RECORDING A VIDEO AT NIGHT
The flash unit is for still photos only. By design it can not be used when shooting video, because it can not stay lit (the flash fires from a stored electrical charge, and needs time to build up another charge).
May 02, 2008 | Canon IXUS 960 IS Digital Camera
The Camcorder
it work 100%nice outdoor shooting in daylight.
I think u have to use another small flash light in indoor in the insufficient light.
I did that and got good result.
Jan 16, 2008 | DigiLife DDV-C330 Digital Camera
Kodak DX 6490 Flash
Hello, When taking photos in low light or night time,turn the rotary dial that you use to turn on the camera all the way to the right as far as it will turn.the symbol looks like torso of person with a star above it. this is the night setting,exposure time is increased so you may have to rest camera on solid object to prevent blur.This should do the trick.
Best Regards,Russell
Oct 11, 2007 | Kodak EasyShare DX6490 Digital Camera
Aiptek A-HD 720P Flash Media Camcorder Logo
193 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
Larry Stiles
Larry Stiles
Michael Galve
Michael Galve
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
