Question about Canon PIXMA MP780 All-In-One InkJet Printer
Mp780 waste ink full
Printer wont reset/clear out of check printer mode on screen
Same problem, after clearing waste ink tank and resetting, now I get the check printer error and the amber light flashing slow.. help?
  • 1 more comment
  • flightmike Mar 20, 2008
    Thanks for your time. Exaclty how do I clean the waste tank? Where is it?
  • Anonymous Apr 26, 2008
    We are also facing same problem, now getting message as Check printer , give us the solution, we can't take print or copy & fax .Give us the solution at the earliest.
  • Wizzym May 20, 2008
    My printer keeps doing the same thing after I followed the instructions, the solution didn't help me. But I appreciated someone taking the time to try helping.
  • 11 Answers
CANON MP 780 WASTE INK COUNTER RESET
Enter Service Mode : Menu – Scan – Copy – Scan
Select #7 PRINTER in the service mode, and
input “0” at # 5 INK ABS CAPA.
Posted on Mar 11, 2008
Message on printer "Waste Ink near full"............. Where is the waste ink tank?
Right under the resting place of the cassettes. However just emptying will not fix it you need to find the reset software for your model
It covers the whole of the bottom. Remove it carefully noting how it fitted. Make a solution of teaspoon of bleach to 1 cup water dunk in a few times to remove ink. Pat dry and finish carefully with a hair dryer on medium. Then replace and follow these instructions
Canon MP780 Waste Ink FULL Reset (Should work with MP700/730/750)
This reset should be used once waste ink counter reaches full and lock-out occurs.
- To select something... Use the '-' and '+' buttons and then the "OK" button.
- To go back... Use the "Stop/Reset" button
- To reset... Use the "On/Off" button (only after you've gone back as far as possible it seems)
  1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
  2. Select "TEST MODE"
  3. Select "[8] ETC.."
  4. Select "[4] EEPROM CLEAR"
  5. Select "[1] INK COUNT"
  6. Press the [OK] button.
  7. Press the [Stop/Reset] button (Exits Service Mode)
  8. press the [ON/OFF] button (which resets the printer)
Reboot and enjoy
please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Screen says "waste ink near full" - what should i do?
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once
Jan 28, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Waste ink absorber full message showing on Cannon Pixma MP760. How to fix?
Follow this instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
Don't forget to replace the ink absorber.
Oct 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Epson R320 Service required message
Reset waste ink counter using SSC ver. 4.30. You can find at indoreset.blogspot.com. Don't forget to replace waste ink pad, washing or extend outlet pipe from head cleaning mechanic to outside of printer.
Jul 23, 2009 | Epson Stylus Photo R320 InkJet Printer
Printer screen says waste ink near full
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Mar 31, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Smartbase MP390 Printer - error code #345
"waste tank full" alarm; you may need to reset the waste tank counter.
Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Dec 17, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Waste ink tank full
try resetting printer as follows.
Reset Waste Ink
By pressing Menu, Copy, Scan, Copy, Copy
6) Press the [Set] key.
Jun 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Waste ink
yeah try this.
Reset Waste Ink
Jun 27, 2008 | Canon PIXMA MP130 All-In-One InkJet...
you have to enter a certin sequence to get it to reset
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
thats your service manual follow the instruction on it
Nov 07, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Aug 03, 2007 | Cannon MULTIPASS C530 Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
1,570 people viewed this question
old marine
old marine
