Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Hoover 500 top load washing machine - water in-flow very, very slow
What can i do as it takes about 1 hour for the water to fill into the machine every wash or rinse!
Pls help ^j^
  • Anonymous Mar 26, 2014
    detergent feed seems to be impeded at base of machine, but I cannot figure out how to get the wheel assembly out of the way so I can clear the clog or figure out what else might be the cause.
    President:
  • 1,673 Answers
Check the water valve. Most of the hoses that are hooked to the water valve have a screened filter, turn water off, unhook hoses, check to see if they need to be cleaned. Other wise the water valve is bad and will have to be replaced.
Posted on Jan 18, 2008
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
Water will not dispence while cleanning
Before using tool
It may be necessary to remove air from
the system ("prime the pump") so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning
.http://hoover.com/file/604/
Sep 18, 2012 | Hoover SteamVac F5914-900 SpinScrub...
It fills up with water in the reserve to the top and flows onto the floor
There is a float switch that should stop the water from picking up when the regular reservior fills. I dont know what machine you have, but assume it is a Rainbo or a Black and Decker. You will need to replace the float switch to repair the problem Go on line and google your machine do it yourself repair manual. You can down load it free of charge. If the machine is under warranty, call the store or where ever you purchased it.
Feb 03, 2011 | Vacuums
Have a hoover steam vac that wont **** up the water brushes spin
Look at the bottom, where the water comes out and comes back in? Is it filled with hair/dirt? It might need to be cleaned out where the water sucks up in at. Otherwise I would go to Hoover.com website for f.a.q.s or technical support.
else
If you find that your cleaning solution will not dispense, check that the tank is securely in the locked position. There is also a chance that the solution tank is empty, in which case fill it with cleaning fluid. Ensure that the recovery tank lid is firmly in place.
or
Prime the pump. Priming means to remove air from the system so that the cleaning fluid can flow to the tool. You "prime the pump" by attaching the tool to the hose and turning the carpet clearer to ON. Then put the tool on a hard surface or against your hand to block the suction. It may take up to 15 seconds to remove all the air. Once this is done, squeeze the trigger on the machine and begin to clean.
Thank You.
Jul 18, 2010 | Hoover Vacuums
Do you put water in the big compartment under the solution compartment when wet washing your floor
You put water and Hoover Cleaning Solution into the top tank. Push down on the release button at the top of the tank just below and in front of the handle. The cap is also your measuring cup. Fill it with the Hoover Cleaner Concentrate. Pour that into the tank and fill it to the fill line with warm water.
The dirty water will be extracted into the bottom tank.
May 20, 2010 | Hoover H3030 FloorMate SpinScrub 500...
I think the trigger on my upholstery hose is broke how can i tell? trigger is loose- water just flows out and i have to shut the machine off. i have a hoover steam vac dual deep cleaner
The most common issue with this is the white nozzle tip broken. sometimes it comes out. it still could be the trigger. take it to a shop and they can tell right away. the trigger is spring loaded, you should feel tension.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 09, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac..F7452-900. not working in wash-auto rinse mode
This problem sound like you hav a problem with the pump. I would take it to a shop for service
Sep 26, 2009 | Hoover F7452-900 SteamVac Upright Vacuum
Replacing water pump - Hoover Jet & Wash S6254 001
I have an S6254 001 Hoover jet & wash and have just taken the pump apart to free sticking parts. To get into the top you have to prise off the handle cover to get to 2 screws, unscrew them and the rest is fairly straight forward.
Regards Stu
May 17, 2009 | Hoover U5750-900 WindTunnel Bagless...
Hoover Steam Vac
take off dirty water tank look for small screen usually at the top behind tank remove debris from screen!
Oct 19, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover F7210-900 SteamVac
Before you take it back, check the filter inside the lid of the recovery tank, if it is all of the way to the top, it will cause problems, it needs a 1/4 in. gap from the top. Might be also that the plunger in the handle is pushing all of the way down so as to release the water.
Nov 22, 2007 | Hoover F7210-900 SteamVac V2 Upright...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
131 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
