Hitachi I cannot program all the channels into my television and some other features do not work from the menu list on the remote that came with the television. I need a universal to work with the menu on my television. I thee such a remote? Thank you Gary LaSaga
  • 5,138 Answers
Go to menu look under cable/air switch to cable if you have cable then look for Auto Programming press go this will then automatically program all channels that you reviced, a universal hand unit can not do the things that your hand unit can do ! If you need more help let me know.
Posted on Jan 18, 2008
6ya staff
SOURCE:
The menu feature does not work on my philips 55pw936317f
Make sure you are using the original TV remote
Feb 11, 2013 | Philips Televison & Video
Do I need a converter box for a Hitachi 53uwx10ba TV?
Check to see what input the set is on--set in menu to catv or cable and connect with set on three if using a box---if not then auto program for channels.
If set on catv you should with the remote be able to direct enter a channel to see if tuner in set works or hook a dvd etc to a rear input to set to see if it works that way.
Nov 03, 2012 | Hitachi 53UDX10B 53" Rear Projection...
I lost my remote for hitachi CMP401XU and i dont know the remote # so let me know which remote i bye for it
any universal remote would work but hte hitachi remote for that model is expensive i suggest buying a logitec harmony universal remote for around 40 bucks from amazon. you plug it into you computer and just type your model number in it will install all the original options to this remote plus allow extra features such as activities where it can change the channel on your tv and turn your cable box on and let you change volume on your sound system without the hassle of having to use different remotes. and without having to hit different buttons i.e cable button to change channel and tv button for remote it will do it automatically
Mar 15, 2011 | Hitachi CMP401XU 41 in. Television
Lost the remote control, how to i add in cable channels? it will only pick up 2-12 - when we had the remote i could add them in, now that it is gone, how do i do it? when i change channels manually or type...
The replacement for model indicated is rather expensive. What you will find is all Hitachi remotes made from 1999 to date will operate that set.
2-12 means the set is in the Air band and not the cable band. A lot of these remotes are readily available on EBAY and other places, I have several Hitachi remotes and all codes for all their regular tvs, projection, LCD, and Plasma use the same codes.
All you need is a remote that will go into the menu and allow you to select Cable and then go and do auto program.
I have a Hitachi remote for a 1991 projection set and it works on all later sets, only a few features are missing for certain models.
It is either this or try a universal, but I suspect a Universal will not do what you want.
Let me know if you have questions.
SD TECH
Jan 15, 2011 | Hitachi 13GA1B 13" TV
I just set it up (it is used) and I can't get to the "Channel Manager" in the setup menu, as it is grayed out. I can't auto program because of my inability to access this menu function.
Channel menu will be grayed out if tv is set on AV Input, select TV source by remote or press any channel number to set tv on tv source, this will enable channel manager/ menu to tune channels in tv.
Hope these info will help you.
Thanks
Nov 25, 2010 | Hitachi 51F59 51" HDTV Projection...
How to set color, verticl and horizontal lines
Not all universal remote control's operate MENU button on TV!!!
If you have >>COLOR separation ( red blue green) and CAN NOT adjust via MENU button then you must replace conversion IC's>>
part number: STK 392-xxx.....easy repair!!
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Remote doesn't work and I need to access the menu to get to channel 3 to get cable. Hoiw can I get into the menu Toshiba model MW20FM1
purchase a universal remote that includes the make of your TV in the programing list you will have control of volume channel and some other basic features
May 05, 2010 | Toshiba MW20FM1 20 in. Combo
Lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
Apr 28, 2009 | Hitachi C21 F800S TV
Hitachi 51F510 51 in. rear
try to enter your setup menu and auto programed the channels that you receive.
Apr 13, 2008 | Hitachi 51F510 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
