Question about InFocus X1A DLP Slide Projector
Infocus x1 projector
My Infocus X1 projector has started making a fairly loud whining noise as soon as I turn it on. Yesterday it did this for a couple minutes until it stopped, so I watched a movie and after a couple hours it started whining more loudly so I turned off the projector. Now when I turn it on it whines loudly an does not stop. It is not the fan, I know this because if I turn the projector off with the remote the whinin noise goes away but the fan stays on to cool it down and I can hear the fan, it sounds normal.
I fear that it may be the color wheel as it kind of sounds like a high speed power tool, although not quite as loud and the noise isn't steady, it wavers.
Is my projector dying?
  • 3 more comments
  • Anonymous Jan 19, 2008
    I have the same problem you described, however, all I've read on the web suggests there is no fix unless you replace the color wheel at $1000.
  • ecinetcom Feb 06, 2008
    I too started having this problem as of 1/15/08 after using the projector moderalty for several years. I replaced a blown bulb a couple months ago at the cost of $250. Wish I could have seen this coming and saved some money. Still looking for solution or fix on the Net.
  • Anonymous Dec 18, 2008
    I had 350 hrs on this projector and the bulb went.
    Infocus did not assist me in any way and if I didn't have company coming over to watch my new theater setup, I would NEVER had purchased a new bulb($400 plus with the warranty) I bought the warranty because Infocus would not help me on the low aged bulb replacement.
    Now I have the "sound like someone is using a table saw outside" sound.
    THESE PROJECTORS ****!
    The company sucks too,,,,,,they do not stand behind their products.
  • russmazz Jan 17, 2009
    Same exact problem...have cleaned the bulb and sprayed air to clean the fan out...
  • bardiferous Apr 15, 2009
    My X1 made it through the "lifespan" of the bulb. About 50 hours into the new cycle, the sound started.
    I've thought about trying to take it apart and clean it - but I'm guessing that it's a bearing of some sort, and needs replaced. I see others saying, "color wheel."
    Problem Solver:
  • 17 Answers
Indeed, the problem you describe is the Color Wheel. Very common issue in the X1,2 projectors. Unfortunately the only fix is to replace this wheel. The cost of the part generally runs around $175 but the labor to replace is about the same. You will need to find an authorized service center where you live or send it to a repair facility. Parts for any of the InFocus units are generally not available to the public, alas the Service Centers. Maybe for the same cost you could look at a new projector, like I did.
Posted on Feb 18, 2008
It is indeed the color weel. Its has no bearing, so, when it gets old, the shaft starts to scratch the motro case until finally brokes (i have a infocus x1 with a perfect color wheel) my problem is that some liquid, wather or soda o wisky or whatever, droped in and spoil the DMD unit, if i dont find the spare part or replacement, ill sell the color wheel. if interested... [email protected] or if youre having a new projector and can sell me the DMD... haha
Posted on Oct 20, 2009
  • postte
    postte Nov 12, 2012
    Do you still have the color wheel?
6ya staff
SOURCE:
Viewsonic Projector PJ506D not working
the colorwheel is wearing out and need replacing.
Aug 19, 2009 | InFocus X1 Multimedia Projector
Fan noise loud, bulb burst. Replaced with new bulb. Noise even louder! Unit shuts itself off.
the bulb may have burst from overheating from a fan not working to cool it down. and it can be replaced. it does take, however, a while to replace it because you have to take half of it apart. but make sure it's the fan first. take the lamp door off and remove the lamp. use something small and thin to push in the switch that the lamp door usually activates. turn the projector on and see if the lamp fan and the colorwheel (the multicolor glass disk) are spinning. if the fan spins, the noise may be from the colorwheel motor going bad. the fan can be purchased through an infocus authorized service center. check the website for the closest one. but the colorwheel for the x1 cannot be purchased seperately from the optical engine, and that costs a fortune. but here is the part number for the 80mm fan- 526-0152-00.
May 23, 2009 | InFocus X1 Multimedia Projector
Infocus x1 noise problem
the colorwheel motor does burn out after a while (from heat and dust), but as long as it spins at the right speed, you won't see a problem in the image. if it's making noise, it's going to go soon. it does need replacing. however, infocus does not sell individual parts for the x1 optical engine. you will need to replace the entire engine, which costs up to $2000. so, enjoy the last few hours with your machine and look into getting another.
Mar 16, 2009 | InFocus X1 Multimedia Projector
Apple InFocus X1
It seems like your main card is not functioning.
pls check :
1. Color wheel is rotating or not.
2. Recheck Main card connectors.
mail me for any changes
Viren
Jul 16, 2008 | Apple InFocus X1 Multimedia Projector
Loud Noise
Hi topher1234
I will need your Make and Model of the Projector , before I can do a diagnosis. Also include if this is a LCD or DLP machine.
Together with the above , can you feel any vibration on the Projector when you place your hand on it ?
Apr 19, 2008 | InFocus X1 Multimedia Projector
Con: Infocus x1 and infocus x1a projector
Hi there
You could most probably do that yes , it's normally only the Mainboard that is different.
Mar 21, 2008 | InFocus X1 Multimedia Projector
Infocus x1 keypad.. need help
the same functions should be able to be accessed via the remote as well as the keypad on the projector. press "menu", settings, system and de-select "rear" or "ceiling" whichever is causing the "inverted" image
Feb 05, 2008 | InFocus X1 Multimedia Projector
Infocus x1 image issue
the light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Sep 29, 2007 | InFocus X1 Multimedia Projector
1,535 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
