Question about Sony KP-57WS500 57" Rear Projection Television
Displays do not appear
When i change the volume, press display, or press menu button...it does not display on screen
    President:
  • 4,402 Answers
The jungle ic is what controls the OSD, I would start with that.
Posted on Jan 18, 2008
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
How do manually reset sansui lifepad to factory default settings
Try this:
1. Hold down power and volume up buttons for 10 seconds, then press volume down button.
Failing that, this:
1. Turn tablet off. Hold down power button until 'Device Option' menu appears.
2. Select 'Power Off' then 'OK'
3. When tablet has switched off, hold the 'Reset' & 'Power' buttons simultaneously for about 10 seconds.
4. Wait for screen display, then press 'reset' button.
5. The 'system recovery' screen should appear.
6. Use 'Home' & 'Menu' buttons to navigate the menu.
7. Select the 'wipe data/factory reset' option & press 'Reset' button.
8. Then select 'Yes- delete all user data' & press 'Reset' button.
9. Press the 'Reset' button to reboot/restart tablet.
Oct 15, 2014 | Computers & Internet
Hard reset motorola atrix dual core smartphone
  1. Power off the phone.
    NOTE: If unable to power off, remove and reinsert the battery.
  2. Press and hold the Volume Up + Volume Down and the Power button.
  3. The screen displays Boot Mode Selection Menu; press volume down key to cycle through choices until Android Recovery is viewed. Press the Volume Up key to boot in this mode.
  4. Wait for the triangle ! / Android screen to display, then proceed to step 5.
  5. Press both Volume up and Volume down key simultaneously. A recovery menu displays.
  6. Tap on Volume Down key until Wipe data/factory reset is highlighted, and tap the Power button.
  7. Another confirmation screen displays. Tap the Volume Down key until Yes displays, then tap the Power button.
  8. After user data is cleared, the reboot system now option is highlighted by default. Tap the Power button.
  9. The phone reboots to the initial setup screen.
Wireless
Nov 23, 2013 | Motorola Mobility Nice Atrix 2 4g Hd At&t...
Coil not reset odo after oil change please let me know how I can reset
1 Turn key in electronic ignition switch control
unit to position " 1"
2 Press the system select button (S110s3)
repeatedly until the basic display (kilometer
reading display or temperature display) is
shown in the multifunction display (A1p13)
3 Briefly press trip odometer reset button (A1s3) 3
i A signal tone sounds and the voltage
times. display appears in the multifunction display
(A1p13).
4 Press lower scroll forward/back button (S110s1)
i The "Service menu" appears in the
multifunction display (A1p13).
5 Press buttons + and
-, setting of specific
functions and volume control (S111s1)
repeatedly and select "Confirmation" menu item
6 Press lower system selection button (S110s3)
i "Confirmation" appears in the multifunction
to confirm. display (A1p13) and the menu item "Complete
service" is shown against a sight bar in the
background
7 Press lower system selection button (S110s3)
i "Service confirmed" appears in the
to confirm. multifunction display (A1p13).
8 Press the upper system selection button
(S110s3) repeatedly until the "Service menu" is
9 Using the + and
-buttons, setting of specific
functions and volume control (S111s1) select
the menu item "Special work"
10 Press lower system selection button (S110s3)
to confirm.
11 Using the + and
functions and volume control (S111s1), select
menu item "Service 3"
12 Press lower system selection button (S110s3)
to confirm.
13 Select the button + and
-, setting of specific i "Standard oil" or "Oil quality 229.5".
the specification of the engine oil used
i
If only one oil quality is approved for the
engine, no oil selection is possible.
14 Press lower system selection button (S110s3)
i The message "Item confirmed" appears in
to confirm. the multifunction display (A1p13).
Copyright DaimlerChrysler AG 10/10/06 G/09/06. This WIS printout will not be recorded by the update service. Page 1
15 Press the upper system selection button
(S110s3) repeatedly until the basic display
(kilometer reading display or temperature
display) is shown in the multifunction display
(A1p13)
16 Turn key in electronic ignition switch control
unit to position " 0"
Copyright
Jun 22, 2012 | 2006 Mercedes-Benz R-Class
How to set clock on a jensen cdx6311 car stereo. Can't seem to find a "clock" button or any button to lead me to the clock to change it.
Press and hold the DISPLAY / MENU button for more than 3 seconds until menu appears in the display. press the DISPLAY / MENU button multiple times until you see time set. Rotate the VOLUME knob clockwise to adjust minutes, and counterclockwise to adjust hours.
Mar 15, 2011 | Car Audio & Video
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 2
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
How do I reset the printer to the english language panel display
Follow these steps to change language setting on the printer display :
1.On the printer control panel, press the Left arrow twice or the Right arrow seventeen times on the Menu button until SELECT LANGUAGE? appears on the printer display screen.
NOTE: If the language is currently set to a language other than English, the Select Language? menu option will appear in that language.
2.Press the OK button.
3.Press the Left or Right arrows on the Select Photos button until your desired language appears.
NOTE: Even if the printer is currently set to another language, the name English will appear in the English language.
3.Press the OK button to select the language. A message requesting confirmation of the selection will appear appears. If the correct language is displayed, press the OK button. If the incorrect language appears, press the CANCEL button and start the selection process again.
4.When the SELECT COUNTRY/REGION? setting appears on the printer display screen press the OK button to continue.
5.Press the Left or Right arrows on the Menu button until the desired country/region appears on the printer display screen.
6.Press the OK button to select the country/region.
Nov 07, 2010 | HP PSC 1610 All-In-One InkJet Printer
Sony KP-57WS500 57" Rear Projection Television Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
