Home | Kenmore | 16602 / 16604 / 16609 Built-in Dishwasher | Kenmore dishwasher won...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Problem for Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore dishwasher wont start blinking clean light
By sears123 on Jan 18, 2008
our dishwaher has a clean light blinking wont start
Same Problem
May 08, 2009
-   I had the Clean light on and no wash capabilities.
I used the Normal Wash, Heated Dry, Normal Wash, Heated Dry fix it method, all the lights came on, and it started working.
I told the wife it took hours to fix, HA
Thank you so so much-   Guest
May 08, 2009
-   wow great job that heat dry heat dry helped me to thanx alot -   Guest
Dec 27, 2008
-   I want to kiss the person who advised the normal wash..heated dry repeats! It fixed my problem immediately!!! Thank you so very much!
-   fixerfailure
Sep 04, 2008
-   I had the same problem. Kenmore dishwasher - cleaning light still blinking - can't start regular wash. I followed the persons advice on hitting normal wash-heat dry normal wash-heat dry keep doing that until all lights light up - it will start running. he said to hit the start button until turns off - but i'm just letting the wash cycle run and i'll see waht happens! but I am sooooo happy that it worked! thank you! now I don't have to spend money on a repair man and I can tell my husband I fixed it all by myself and I won't tell him my secret! ;)-   nina333
Aug 31, 2008
-   Blinking light indicating electricaLproblem from manual. Unit less than two years old.
Took washer out unhooked and checked all points, all seem okay. Rewired and hooked up all hoses etc and still no luck!
Dishwasher still maintains flashing green light.
What could be the problem?
-   Carrots 18
Best Solution
posted on Apr 30, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try pressing normalwash-heatdry-normalwash-heatdry-normalwash-heatdry-normalwash-heat then all the lights come on. Let run for a little bit. then keep pressing the start button. untell the unit shuts off, then try running a cycle. The control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking their is something wrong with your heating cycle.
Solution #2
posted on Jan 18, 2008
Helpful)
courtdate
Rank: Wiz
Rating: 85%, 730 votes
REPLACE WATER INLET SOLENOID
Was this helpful?
Yes
No
Solution #3
posted on Sep 27, 2009
Very Helpful)
brown919
Rank: Apprentice
Rating: 100%, 1 votes
I did it!!!!!!!!!!!!!!. I can't believe it worked. For a week now that green clean light has been blinking. I thought I was going to have to call somebody to fix it but thankfully I found this website. Thank you soooooooooooo much.. I am so proud. I have got to call somebody and tell them I fixed my own dishwasher (with a little help from you guys). Thanks again.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Sep 24, 2009
Very Helpful)
rjaws
Rank: Apprentice
Rating: 100%, 4 votes
Same situation...flashing "clean" green light...could not run any cycles...tried the poweroff, didn't work, then read the advise on pressing "normal wash - heat dry, normal wash - heat dry" then all lights lit and it worked!!! Great advice, thank you very much. Manitoba, Canada.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #5
posted on Apr 08, 2009
Very Helpful)
Guest3333
Rank: Apprentice
Rating: 100%, 3 votes
just to add details to the wonderful Solution #1
... after all the lights come on, stop pushing buttons and wait. The unit will start up after a couple minutes.
THANK YOU, Guest and FixYa!
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #6
posted on Jan 10, 2009
Very Helpful)
B-52
Rank: Apprentice
Rating: 100%, 6 votes
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #7
posted on Oct 07, 2009
Not Rated)
dpalmisano1
Rank: Apprentice
Rating: 0%, 0 votes
Thank you for this web sight,you saved me from dish pan hands.My daughters b-day is coming and I needed my washer back.The blinking red light mystery is solved.THANKS ALOT
Was this helpful?
Yes
No
Solution #8
posted on Jul 07, 2009
Not Rated)
nobox446
Rank: Apprentice
Rating: 0%, 0 votes
THANKS SO MUCH! "normal wash-heated dry...." reset it and I got all the blinking lights... It went through all sorts of cycles and all of them seem to work... before the washer would not do anything! I just told it to do a normal wash cycle now and am sooo happy we don't have to call Sears! My boyfriend tried looking at the manual to fix it and got no where and I just did a google search and found this helpful site right away!!! THANKS... I can't wait to tell him I fixed it in 5 minutes!
Was this helpful?
Yes
No
Popular Solutions for Kenmore 16602 / 16604 / 16609
Questions and Unsolved Problems for Kenmore 16602 / 16604 / 16609
Do you recommend Kenmore 16602 / 16604 / 16609 Built-in Dishwasher?
Answer
Answer
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed... (More)
Answer
front control panel not working properl, cannot push start
Answer
Wont fill with water. And i out a new solenoid on it
10 Other Users Have The Same Problem - Continued
Comment by Denise Carol, posted on May 26, 2008
Our Kenmore dishwasher clean light keeps blinking and we can not cancel nor start a new cycle. We turned off the breaker, checked for blockage, reclosed the dishwasher. What else can we try? Thanks Denise Walters
Comment by Monkey_Lady, posted on Apr 07, 2008
We've tried hitting cancel and opening and reclosing the door and drawers. We even turned off all power to the dishwasher for 8 hours...clean light still comes back on and just keeps blinking once power is restored. This is for Kenmore QuietGuard3, stock #17022
Comment by Guest, posted on Mar 24, 2008
Kenmore Ultra wash quiet guard 4, model # 66517032401 can't start dishwasher. clean light stays on
Comment by Guest, posted on Mar 02, 2008
Comment by Guest, posted on Feb 25, 2008
Kenmore dishwasher start button blinks three times without starting
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 16602 / 16604 / 16609...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
