You can find and download your required driver from the following links.
http://www.bioticaindia.com/p4vm800m7.html
http://www.findmysoft.com/drivers/download-Mercury-P4VM800M7-1-0-bios-driver.html
http://www.torrentreactor.net/find/mercury-p4vm800m7-motherboard-driver
Download this utitility from this link;
http://www.filebuzz.com/fileinfo/35718/DriverMax.html
It will help you to download your required driver.
Good Luck
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
you might have to get a portable usb sound card if you mean dont have a sound card installed
hope this helps
hope this helps
