Question about Frigidaire GLTF1670A Front Load Washer
Greasy mark on cloth and noise
The wash became more and more noisy. In the latest week some Grease appear on the clothes during big wash. After the drum make so much strange noise that I need to get it repaired. Is it worthed.
  • Anonymous Jan 26, 2008
    Our washer is very noisy when in spin cycle. Now grease is appearing after wash. I fell it is a bad bearing or transmission leaking.
  • 125 Answers
The rear bearing is most likely the cause, High efficiency detergent is a must with front loaders. Most likely not worth repairing unless you can do it yourself. Having it done would most likely run at least 350.00 - 450.00. Call a local servicer, A&E (aka sears) would charge 1,000.00.
Posted on Jan 21, 2008
Black marks on clothes
Possible that the machine needs a good clean up and so it is best to use the right cleaning method.
please check this link : cleaning washing machine
Jun 06, 2012 | Maytag Washing Machines
Greasy marks on clothes in top loading washing machines can also be caused by...
90% of greasy marks on cloths is due to scum build in the outer bowl of your loaders being the most vulnerable. prevention is better than cure. At least one hot wash a week on high level. If your machine is an early model one or two with a good bleach subject to manufacturers instruction...bleach is very cost effective and works well.
on Apr 09, 2008 | Bosch WFMC 3200 Front Load Washer
Greasy marks on cloths; All washing machines
on Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Stains on clothes after washing. Appears to possibly be oil residue. Is there a rubber seal or part that may be leaking inside the drum?
This could be a couple of things
1....oil from the transmission.
this is not common so lets leave this one
2.....the use of fabric softener causes greasy marks on clothing after a while
Fabric softener reacts with soap and can form a greasy jell. it can be yellow oily color or black.
You will know if you have been using fabric softener.
Stop using it straight away.
To clean oty the machine if it were mine I would put a packet of epson salts in with hot water and let the comp[lete cycly go.
Foe awhile use the machine with caution as this may release build up of grease which can stain further clothing until it is all gone.
The make and model of the washer is needed for an accurate diagnosis.
Aug 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Oil marks on my clothes after washing
It could be an indication that the main bearings are failing, or it could be an effect known as grease balling.
This is caused by washing at too low a temperature, or not using enough powder, or using the wrong type of powder.
If it is the bearings, then I would expect it to be getting noisy, particularly on the spin cycle.
Hope this helps.
Please rate my solution.
Feb 01, 2010 | Select Brands Washing Machines
Clothes getting greasy marks
There is nothing that has grease on it that can leak into the dryer I would do a good inspection in the drum and clean it.
Dec 13, 2009 | GE Dryers
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Clear greasy stains appearing on clothes from brand new LG front loading washer
the grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
Sep 28, 2008 | LG WM2487H Front Load Washer
Noisy and Oil Marks
bearings have failed. replacement is quite a hard job if you haven't done it before but parts quite reasonable. let me know if you want to go ahead and i can give you some instructions
Jul 12, 2008 | Zanussi F1245W Front Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
