Cd-rom won't open easily
Every time i try loading a cd my cd drive won't open easily. I have to try or pushed the opening button several times before it will open.
  • Anonymous Feb 11, 2008
    Same problem earlier and stopped working as of lately. won't even open up now
  • shaliwo Nov 21, 2008
    I have the issue which is similar to this. CD/DVD won't load easily. It makes a lot of noise while loading. Recently, I find that the driver CD which was supplied by ACER fails to load...
  • 44 Answers
If you can't open the shelf, try to put a gem into the small opening in the front of the shelf, it will also be able to open the shelf in the old versions of WMP, I think^^. Good Luck! Regards, David.
Posted on Jul 08, 2009
If this is on your PC then try opening your CD Drive as soon as you power up. If it opens easily at this time but not AFTER it has booted up then you have a driver problem.
If this is the case I would remove the drive from the system, ie unplug the unit both power and ide cable, then reboot twice to take it out of rotation. If it is not the case, then your on board cd controller is bad, just replace the drive.
Next, after powering down, connect the CD Drive to a different IDE controller. Power on and then check the opening of the door. You will have a 66% chance of fixing your problem this way.
Good luck.
Posted on Jan 18, 2008
My cd rom will not open what can i do
  1. Software can lock the CD drive preventing you from ejecting. If this is the problem, turn off the machine, turn on, when the DELL screen flashes, push the eject button several times and the CD will eject.
  2. If that doesn't work, look for a small hole the size of a paper clip and gently push a paper clip into it. When you meet resistance, the drawer will start to open. You can then pull it open carefully. The computer can be off when you try this.
  3. If neither work, then you might have a jammed CD, i.e. incorrectly inserted. You can try to force the drawer open with your fingers but don't use so much force you strip the plastic gears.
Aug 14, 2010 | Dell Dimension C521 PC Desktop
I can't open my DVD-Rom drive and it doesn't read the information in my CD drive? It's an HP Media Center PCm7334m, computer.
Aug 14, 2010 | HP Pavilion Media Center TV m7330n...
Cannot open d compartment
U just use a ejector pin. Means, your CD Rom have small hole (Front Side). When u push the pin your CD Rom hole, at a time u push your CD Rom ejector button. Than open.
Jul 12, 2010 | Samsung Computers & Internet
My DVD-ROM tray opens only after many tries.
As per your information you done all the basic work. Hope you use little bit of oil drop in the side of the tray. If not then try that .If no success then there is a small spring available for tray in and out function. You have to change that spring from a service center or if possible then at home.
Thanks and waiting for your reply.
Feb 04, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
What can i do to open the door on my ez-dub
HI Buddy If your cd drive not opening no prob haah,, i have solution to open this, near by your cd room button there would be whole tiny whole ok, you have to do that when u pressed the button same time your have to entered the pin in to whole then your cd drive will come out easily.
if u will suceed then reply me plz ok best of luck.
Feb 28, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Cd rom drive won't open
i had the same problem i solved mine by using a knife and using the tip of the blade to push up and pull out on the drive while it tries to open and drive opened with out a hitch.. it turned out to be a gear problem with the drive.
Jan 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
Disc tray will not open
a small orifice is given there in cd-rom near a push or open button or LED in front side of the rom.take a niddle and enter it in that hole, rom will be opened
Jan 20, 2008 | Computers & Internet
CD Rom
Well...first lets make sure the drive still can physically open.
http://i36.photobucket.com/albums/e40/freddyhard/CD13.jpg
There in the picture will show you where the manual eject button is. Use a paperclip and push the button in the hole. Once the drive is open enough for you to pull the tray, go ahead and pull it as far as it will come out. It will stop, and it shouldn't come all they way unattached from the rest of the unit.
Go ahead and take any cd or dvds that was in the drive out and turn your computer back on.
Once into windows, push the regular eject button and the drive should close the door itself. Let it sit for a second or two, and try hitting the eject button again. 9 times out of 10, that usually fixes my drives.
Hope this helps!
Jan 15, 2008 | Memorex 32023252 Internal 52x CD-ROM Drive
Cd-rom/dvd-rom door won't open
Hi!This is not a big problem...All you have do is take a pin, needle or something and just insert it into the small hole near your cd-rom drive..try this repeatedly while pressing the eject button..If it doesn't work you will have to unscrew the two screws on the right of your keyboard..doing this will give you the access to the cd tray and you can remove the cd and put it back together..
Nov 13, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
1,031 people viewed this question
David Payne
David Payne
