Question about Bosch WFMC 3200 Front Load Washer
Door trouble we have a bosch wfmc3200. the door is open but the lock is still engaged so the door will not close. if i turn it to a cycle, the screen flashes "E:". I've unplugged it but the lock still will not disengage. Help!
  • 139 Answers
The door helps the the interlock to open as the door latch as it helps the latch spring back....
All you need to do is use a screw drive to pull the doorinterlock back into place...
with the machine off of course.. just gentley play with it and it will open....
any questions dont hesitate to ask
Posted on Jan 21, 2008
I have a Bosch 300 Series front-loading washer. When the door was open, the door locking mechanism somehow engaged and now I cannot close the door.
If your door refuses to close and the handle appears to be fine, this could likely be a fault with the door lock. You will need to replace the lock.
Apr 30, 2018 | Bosch Washing Machines
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a Bosch Intelligent frost Free 44. It keeps on switching on and off the whole time but when I leave open one of the doors, it runs normally. What could the problem be?
faulty thermostat
the thermostat presets on on/off temperature is faulty and when the door is close it is cycling but when the door is open the cycle is not allowed to happen because the on tremp is engaged full time
get a technician in to properly diagnose the fault and quote .
Aug 30, 2016 | Bosch Refrigerators
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Bosch dishwasher purchased in 1996 or 97. The dishwasher stopped working part way through the wash cycle. The on/off light does not come on. The on/off light does come on, at times, when you...
It sounds like the problem maybe with the door lock circuit. This is a safety feature that is the door lock mechanism, it completes the circuit to allow the dishwasher to run when the door is locked. Reading your trouble note you state the light goes out when you attempt to close the door. Light out means there is no circuit through the door lock mechanism so the dishwasher will not work. Take a look at the lock with the door open, make sure it seats properly, though it maybe opened internally, this would require a professional to fix.
Feb 21, 2011 | Dishwashers
Bosch Washer WFMC3200.
Contact a Bosch technician. You may have to at least pay for a service call.
Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
first of all, start with you close the door,you put the set on and continue please
Door Open, Door Latch Locked
yes that loop is the release.
if you pull push it and its stiff , spray some wd 40 in the unit .
its likely binding against the plastics.
so just spray away and wait a few mins.
many folks says lubing it is a fix.
May 03, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
163 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
