Question about HP iPAQ RX3715 Pocket PC
IPAQ file store problem
I can't delete the files in the iPAQ file store. I also tried formatting iPAQ file store but nothing happened. what shall i do?
    Problem Solver:
  • 15 Answers
You're not alone! Virtually every ipaq rx3715 gets this problem at one time or another. Unfortunately, it is a massive memory issue. Be prepared to potentially lose all of your data, including programs. My suggestion would be to back up your ipaq before you do this. I do not know if the backup retains the memory error, but what I would do is back it up, perform the fix, and then restore the data back onto the ipaq. If your file store problem is fixed, there you go! If the problem comes back upon restoring the pocket pc, then unfortunately you will lose all data and programs in order to fix the memory, and that will be a personal choice. For most of us, the ipaq simply freezes up upon entry into the file store, so consider yourself lucky that they simply do not delete.
Here is the step-by-step process of how to fix your problem.
1. Download GER and ENG ROMs (latest) from HP's support site
2. Unpack both
3. Cancel the automatic flash procedure.
4. Locate the EnterBootLoader.exe file in the folder of the unpacked GER update
5. Copy it to PPC
6. Run it from the PPC
7. Run the ROMUpdateUtility.exe file from the desktop to start flash procedure.
Then you have a German-language PPC
8. Locate the EnterBootLoader.exe file in the folder of the unpacked ENG update
9. Repeat steps 5-7 for the English update
You're done
Remember, you're not alone! We all had the same problem.
Posted on Mar 01, 2008
Trying to backup my 2415 iPaq. It used to save .exe files. Now, it only saves .pbf files. What's the difference - or does it make any difference at all? Also, I have a second iPaq that does NOT...
an .exe file is an EXEcutable file, it is the file that starts a program. It is not the backup data, but it may be the program that captures it.
Your .pbf files are indeed backup data files by Paragon backup and recovery program.
So, you would open Paragon using its .exe file and it backs up the data to .pbf files. To restore the files, you would open Paragon, and point to the last .pbf file or files to restore.
And yes, you could have Paragon Backup and Recovery on both machines and save the backups to a USB memory stick. What is on the memory stick can be accessed by Paragon on both machines. Make sure it is data only, rather than system files unless each computer is absolutely identical in model and spec.
PBF File Extension - What is a .pbf file and how do I open it?
https://fileinfo.com/extension/pbf
Backup archive created by one of Paragon's backup and recovery applications; stores backup files in a proprietary format; can be browsed within the software, which enables users to restore individual files or a whole file system. In addition to system backups, PBF files are often ...
File Extension .PBF Details
filext.com/file-extension/PBF Details for file extension: PBF - Grand Prix Legends BMAP (Bitmap) File :: PBF - Paragon Disk Image :: PBF - PBook E-book Format :: PBF - Portable Bitmap ...
How to view or import *.pbf file (OSM data, binary format) in ArcGIS for ...
https://gis.stackexchange.com/.../how-to-view-or-import-pbf-file-osm-data-binary-for... Oct 25, 2012 - The ArcGIS Editor for OSM (https://github.com/Esri/arcgis-osm-editor) should allow you to do what you want to do. Data is downloaded via the ...
Sep 02, 2017 | HP iPAQ HX2415 Pocket PC
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
Tried to update iPAQ ROM, iPAQ died in middle of Install. Help!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.) Make sure battery is charged
2.) Locate the rom you want to use
3.) Remove machine fro cradle
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your PDA in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Highlight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from your Vendor in step 3.
10.) The PDA should now begin Flashing the iPAQ's ROM BIOS.
Aug 21, 2009 | HP Computers & Internet
ITS BEEN A WHILE SINCE I USED MY IPAQ SO I CHARGED IT UP AND TRIED TO TURN IT ON. WHEN IT DID NOT TURN ON I TRIED TO RE BOOT IT BY PRESSING THE STYLUS IN THE SMALL HOLE IN THE BOTTOM OF THE IPAQ. THE...
a 13 year old relic of the past pulled out of the attic or found at a garage sale for 50 cents.?
hp has no support for this, its now a relic retired state there.
some have 2 batteries , one is soldered down. oops.
first google hit.
https://www.youtube.com/watch?v=OpGzA5Xl4J0
google finds then non HP manual , that HP deleted.
here free, give the new batt. 4 hours to charge.
https://www.manualslib.com/products/Hp-Rz1710-Ipaq-Pocket-Pc-2374427.html
RTM?
read page 27 , carefully and the gravity of these words
"Keep the battery charged.
The programs and files you install or create are stored in volatile RAM memory. If the battery
completely discharges, all user-installed programs and user data files
created will be erased and you will have to reinstall them. To prevent
losing valuable programs and files, keep the battery always charged.
Optionally, you can store a limited number of programs and files in the
iPAQ File Store folder so that if the battery completely discharges, they
will not be lost."
the store, is a NVram?, not flash. and the STORE has a battery
what is the chances of any 13year old battery still good.(zero?>)
see the coin cell here, it unplugs other models are soldered down.
1710-0bqeoaofrldpq4t1wllrhfnq-1-0.jpg why spend cash on old relics like this. and labor?
so you learned to day it has 2 batteries not 1
and learned it is 13 year old relic of the past, 100% useless in todays world. (buy notepad new for $50 at walfart)
Dec 19, 2017 | HP iPAQ RX1710 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
PC/PDA "connected" yet PC won't read PDA
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
Feb 02, 2008 | HP iPAQ H3955 Pocket PC
Trouble formatting card
Did you happen to write files to one of the cards from the computer, or delete files from the card through the computer before that happened? This problem has been known to happen in such cases. Remember to only *copy* files from the card to the computer using the card reader, and only delete files using the camera. Anyway, try turning off the camera, pulling and re-inserting the card. If it doesn't work - try it a few more times. If it still doesn't work and you've got nothing to lose, try deleting any files you may have written to the card using the computer, and then try again. But the fact that the new card didn't work as well might mean that it won't help. Good luck.
Apr 04, 2006 | Olympus Camedia C-150 Digital Camera
4150 and SD card capacity
I had this on a 2GB card. I tried formatting it on my PC but it was still reporting 1GB in use even though it was empty. I then downloaded Pocket Mechanic and formatted it with that on my Ipaq and this worked for me... http://www.pocketgear.com/software_detail.asp?id=12178&associateid=373.
Sep 14, 2005 | HP iPAQ H4150 Pocket PC
Files problem
I think you're in trouble. It's a known bug, and can't be fixed by us on the forums. It's caused by placing overlarge files in the store or by overfilling it. For your reading "pleasure"... http://discussion.brighthand.com/showthread.php?s=&threadid=114651
Sep 12, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
891 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
