Question about Durabrand DWT1905 TV
No sound-picture is great-can't get sound
I have Model BH2004D, replaced batteries in the remote, verified that mute is OFF, volume up to max but no sound. Was watching the TV, left the room and came back and there was no sound.
  • Anonymous Jan 20, 2008
    I have the same problem.
    I cant find the audio in the menu selections
  • deprived Jan 22, 2008
    I can't find audio in the menu selections. Can you list the step by step instructions to get to that option?
I have the same problem. Upon opening the TV and inspecting the main circuit board, I found a capacitor that had apparently blown. However I have had no luck locating a replacement for this capacitor. The numbers on the cap are FNR G31D R2.5-4M 125VAC. Funny thing is, I have two of these televisions identical bought at the same time. I opened the other one to remove the cap and check it and it was burnt as well.
Posted on Feb 06, 2008
  • Durabrand Master
  • 5,138 Answers
Go to menu look at audio see if speakers are on or off turn on speakers for internal use.
Posted on Jan 18, 2008
The volume on my 32 Insignia flatscreen TV suddenly went to max volume and wouldn't go down, both on the remote and the TV
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electro-medical.blogspot.com/
Nov 25, 2016 | Televison & Video
I have picture but no sound on my Panasonic model TC-P4232C plasma hdtv
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jun 25, 2016 | Panasonic Televison & Video
Get my dish reciever, sony home theatre, and 55in sanyo tv to work together
If your TV and sound system both have a Digital Optical Out/In you can use a TOSLink cable (an optical cable) to connect your TV directly to your sound system, and remove the connection between the DISH receiver and the sound system. As long as your sound system is on the right input, all sound accompanying the picture on screen will go to your sound system. Most TVs also have an option to turn off the internal speakers, if not just reduce your volume all the way down to avoid that weird ghost sound effect. If you use your sound system all the time for volume, you can program the sound system to your DISH remote's AUX, and even set the remote so that it only sends volume and mute commands to the sound system (that way you don't have to dance between sat, tv, and aux all day, just leave it in sat mode).
To program your remote to the sound system, follow the instructions on the sheet you got with the remote (yeah, right like anyone kept that) http://www.mydish.com/support/remotecodes you can use that link to program your remote. You can also use the learning mode if your remote has a little glossy square on the top left side and you have the original remote to the sound system. (Learning mode can be gleaned from the remote manual Remote Control Manuals)
After programming the aux device, and verifying that it changes the volume up, down, and mute, THEN:
Hold AUX until light blinks 3 times, hit pound (#), Volume Up, 0 (Zero), pound (#), SAT, then test to make sure it goes up and down.
Sep 24, 2014 | DISH Network Televison & Video
I already asked what to do about the Durabrand model # BH2004D audio not coming back on after using mute.
Hi. There is nothting wrong with your remote as the TV rsponds well.
Have you tried to plug in a head-phone ? Is there sound ? If not, there
is a problem either in the sound detection, or sound signal path in general. This path is mostly bult in a complete "sound final " IC.
Look for cold solderings as well aroung this circuit.
Aug 25, 2014 | Televison & Video
No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    Mar 08, 2014 | Vizio Televison & Video
    Been having sound problems for 6 months.. At first i could just adjust the volume up and down and it would come back on now it won"t come on at all. picture perfect just no sound. Tryed changing from...
    ensure TV's 'mute' is not on. use buttons on TV to adjust volume up and down. if not working properly, you may have a volume adjustment on your cable modem which needs to be turned up to maximum. if sound works, all is well. if sound still not acceptable your TV needs repair.
    if TV buttons adjust volume OK, and your remote for TV does not properly adjust volume, try fresh batteries. if
    remote still not working properly, you can buy replacement on EBay or try a genaric remote from a dollar store. also, i may have an extra remote for you.
    Mar 03, 2018 | Samsung PN58B540 58 in. Plasma HDTV
    The remote control volume up, volume down and mute buttons do not work correctly. You have to play around with them before they work. Already tried changing the batteries. This did not help. Can you...
    Read this procedure to possibly fix the remote:
    http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
    They also sell replacement remotes.
    Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
    or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
    Jul 23, 2011 | Yamaha HTR-5860 Receiver
    My volume button goes all the way up to the max and stays there and sometimes my mute won't work how do i fix the problem
    It looks as if your volume up button is stuck, either on the TVs manual buttons or the volume up button from the remote. To check if it's the remote, put the remote away from the TV, either in a drawer or take the batteries out. If the same check the Volume up button on the TV, it may be pressed down & stuck in this position. If this is ok most likely the volume button will be at fault & need replaced.
    Jul 13, 2009 | GE 31GT660 TV
    Durabrand tv model#BH2004D need code for GE universal remote
    The code for GE universal remote for th Durabrand BH2004D is "0157"
    May 07, 2009 | Philips (PM625S) Remote Control
    Durabrand DWT1905 TV Logo
    297 people viewed this question
    Top Durabrand Televison & Video Experts
    matt martin
    matt martin
    Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
