Games not reading
First some basic steps to troubleshooting
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
Try
to use several similar Xbox 360-compatible discs in the console to
determine whether the disc that you are using is causing the problem.
To test whether the problem is caused by a specific disc, use a disc of
the same type, such as a game disc, DVD movie, or music CD. If the
problem does not occur when you use other discs, that specific disc
might be the cause of the problem.
For disc-specific issues,
check the disc for any visible signs of damage or dirt. Hold the disc
by the edges without touching the top or bottom surfaces with your
fingers. Clean the disc by using a soft cloth. Lightly wipe from the
center outwards. Do not use solvents or chemicals to clean the disc.
If you suspect that the Xbox 360 device could be causing the problem you can follow these steps
1.
If you have access to another Xbox 360 console, try to play the disc on
the other console. Or, if the disc is a CD or a DVD, try to play the
disc on another device, such as a CD player, a DVD player, or a
computer that is equipped to play CDs or DVDs.
2. If you have an
Xbox 360 Hard Drive (HDD) or Memory Unit (MU) attached to the console,
turn off the console, and remove the HDD and any attached MU. Then,
turn on your console, and try the disc again. If this seems to resolve
the problem, turn off your console, reattach the HDD and MU, and then
delete any saved games for the game that is causing problems.
If this does not resolve the problem but removing the hard disk does, clear the hard disk drive cache
To clear the cache, follow these steps:
1. Move to the System Settings section of the Xbox 360 dashboard.
2. Select Memory.
Highlight
a storage device.Do not press the A button, Press the Y button to view
the Device Options screen, Select Clear System Cache, and then select
Yes to clear the cache.
I presume you do not have a hacked
version of Xbox 360 because this problem is prevalent with Xbox 360 dvd
drives which are hacked also if the above steps do not resolve your
issue, please send your Xbox 360 to Repairs, call up MS support and
check for the charges of Repairs in case your Xbox is not covered under
warranty.
