Question about Samsung SPP4231 42 in. EDTV-Ready Plasma Television
Screen black out
Samsung SP-P4231 42" plasma TV. The upper half of the screen totally blacks out. Began intermediatly, but is now daily after the TV has been on about 30 minutes.
Approximate cost for repair? Do I want to trash it or repair it?
Thanks for any help you may have.
  • Anonymous Mar 17, 2008
    pantalla negra tiene audio el let parpadea 5 vece
The power pack is bad
Posted on Aug 26, 2010
  • 29 Answers
This is a upper buffer board problem, the board is not to expensive but the if you are not a repairman, I would not attempt it
Posted on Mar 15, 2008
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Plasma black spots
The plasma panel is trashed-it had taken a hit somewhere and now is loosing the vacuum inside.Soon the whole screen will be black.
The TV will need replaced the plasma panel-there is no other way to fix it.This panel is like a fluorescent tube,one gets air inside ,needs replacement)
Feb 02, 2014 | Televison & Video
I have a 42" Samsung Plasma. We have had it two years so the warranty just ran out. We have a half inch red line down the left side of the screen. Also, when the screen should be black, there are hints of...
ONE OF TWO THINGS, THE LINE COULD POSSIBLY BE FIXED WITH A SCAN BOARD, BUT NOT LIKELY, PROBABLY NEEDS A SCREEN REPLACED, THE OTHER RED STUFF CAN BE FIXED WITH A X-BOARD REPLACEMENT, BETTER OFF TO BUY A NEW TV
Dec 30, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
Bottom half of screen black on plasma tv
Either there is bulging capacitors on the main power board,or the Y Board lower is faulty. If the entire screen was black I would lean toward the Y Main Board,or if the upper half was black then i would say the Y Buffer upper board is defective.
Oct 31, 2009 | LG 60PG60 60 in. Plasma HDTV
Screen was going red on the top half of the screen, then..
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 23, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
My Samsung just went black
If the crack is in the glass - your set should be considered "totaled". The cost of replacing the "display" will probably be more that it worth. If you are under warranty, contact the seller immediately.
Feb 17, 2009 | Samsung PS42A410 42 in. HD-Ready Plasma TV
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung PS42S5hX
This could be caused by the Y-main board or the lower buffer board going bad
May 26, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung SPP4231 42 in. EDTV-Ready Plasma Television Logo
424 people viewed this question
Jerry Greenberg
Jerry Greenberg
