Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Door will go down only if i keep button pressed
Door will only go down if i hold the button
  • duns2 Mar 03, 2008
    I noticed that on one of my sensors on the garage door rail, one sensor light is yellow and the otherside is green. I can only close the garage when I hold the button down until the garage is fully down. The remote opens the door and the button when pressed opens the door also. Smart button blinks 2 times than pauses and blinks 4 times, pauses and blinks 2 and than 4 again. What does that code mean?
  • valentino28 Apr 21, 2008
    I have the same problem...
    The yellow light would not turn green no matter how I align it!
    Novelist:
  • 91 Answers
This is what we call in the buisness a constant hold down , that means that the sensors are not aligned , be careful when checking theese sensors because even the slightest flicker will send a false signal to the opener and not allow it to come down , I have installed over 27 thousand ..yes thousand machines to date and i,ve seen it all also make shure the sensor lenses are free of dirt or cobwebs , so now you need to check theese things and also if you realign the sensor and you only have to do one ! make shure you have a steady solid light, is their is a short in the wire ,you should splice a new wire in its place black to black and white to white as they are color coded universaly, also check for brooms and shovels and the typical junk that people usually put in the corners of the garage ,i,ve had many service calls and just had to move a broom that was in the way of the sensor , the beam must be unobstructed and the lights should be bright and solid without any flicker , also green light is the sending unit and the yellow light means it,s the recieving unit on your sensors , Hope you have luck and i was able to help you ,thanks so much for the questionSincerely glenn
Posted on Mar 04, 2009
6ya staff
SOURCE:
Need instructions
The owner's manual will tell you step by step how to program it. Normally you would follow these steps (with the engine off):
1. Press and hold down the two outsid buttons releasing only when the indicator light begins to flash.
2. Position the end of your hand-held transmitter about 1 to 3 inches away from the buttons while keeping the indicator light in view.
3. Simutaneiously press and hold both the desired button and teh hand-held transmitter button. Do not release the buttons until the indicator light flashes slowly at first and then rapidly. Then releas both buttons.
4. Press and hold the newly-trained button and observe the indicator light. If the indcator light stays on constantly, programming is complete and your garage door should activate when you press the button.
Nov 26, 2013 | Wright Products International VC333BL...
Program garage door to my garage opener in my 2002 yukon Denali
Apr 06, 2013 | Building Materials
Reset drum counter
I found this solution online for you:
Shut off the printer.
  • 2 Hold down the "Continue" button while opening the front door. Then turn on the printer.
  • 3 Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
  • 4 The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
  • 5 Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
  • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
  • 7 Turn the printer off and back on.
  • Mar 27, 2013 | Dell 3100cn Laser Printer
    Reset counter
    By the way, what is the make and model of your printer?
    1. Resetting the Drum Page Counter
      • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
      • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
      • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
      • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
      • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    I hope you find it very helpful. Best regards.
    Aug 16, 2011 | Office Equipment & Supplies
    Nexus 300 change speedo head from kph to mph?
    TO SHIFT FROM km/h TO mp/h: HOLD DOWN THE «MODE» AND «CLOCK» BUTTONS SIMULTANEOUSLY, WITH THE KEY SET TO «OFF». THEN TURN THE KEY TO «ON» HOLDING DOWN BOTH BUTTONS FOR MORE THAN 3 SECONDS. WHEN THE WORD «SET» IS DISPLAYED THE UNIT OF MEASUREMENT HAS BEEN CHANGED
    http://manuals.wotmeworry.org.uk/Gilera%20Nexus/Nexus%20300/Nexus%20300%20Owners%20Manual.pdf
    Jul 03, 2011 | Computers & Internet
    Program a key less entry
    to program your remote --
    1. sit in the drivers seat and close ALL doors and insert the key in the ignition ( do not turn ).
    2. press and hold the UNLOCK button on the door panel ( you will need to keep it pushed down during the next steps ).
    3. turn the ignition switch ( do not crank the starter ) to ON and then OFF and the ON and then OFF again.
    4. now release the UNLOCK button on the door panel.
    5. now press and hold the lock and unlock button at the same time on the remote and hold them until the door locks on the vehicle cycle -- this will take about 30 seconds.
    if you need to program more remotes -- just follow the same instructions with that remote.
    all should be good.
    c...
    Feb 26, 2011 | 2003 Chevrolet Tahoe
    How to reset older 1/3 HP Opener with a yellow learning button
    To clear all codes.
    Hold down the yellow button for 30 seconds.
    Now you can program remotes and keypad.
    Remotes - press and release yellow button. press button on remote and hold for 5 seconds. The next time you press the remote the door should move.
    Keypad - press and release yellow button. within 20 seconds put in desired code press and hold enter button for 5-10 seconds. again the door should move the next time you put in the code.
    Hope this helps
    Nov 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
    I have a quantum model 3212 serial #3000...fcc id #kj8intrmt...ok im trying to program my garage door to my truck..help please
    1. In the vehicle press and hold the two outside buttons until the indicator light begins to flash (after 20 seconds). Release both buttons. Note: Some vehicles may require the ignition switch to be turned to the second (or "accessory") position during the programming process.
    2. Hold the end of your handheld transmitter between 1 and 3 inches away from the Homelink surface (located on your visor or overhead console) keeping the indicator light in view.
    3. Using both hands, simultaneously push the handheld transmitter button and the desired HomeLink button. DO NOT release the buttons until step 4 has been completed.
    4. Hold down both buttons until the indicator light on the HomeLink Wireless Control System flashes, first slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light indicates successful programming of the new frequency signal.)
    To train your garage door opener.
    1. Locate the smart/learn button on the garage door opener motor head unit.
    2. Press and immediately release the smart/learn button.
    Firmly press and release the programmed HomeLink button. Press and release the HomeLink button a second time to complete the training process. (Some garage door openers may require you to do this procedure a third time to complete the training.)
    Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
    My garage door wont go down.I habe to hold the switch down but if i let it go the door will go up again.
    I have a Liftmaster garage door that won't go down unless you press and hold the wall button. The sensor lights are both on. The green light on the unit flashes unless I press the reset button. As soon as you press the wall button it flashes again and the door won't go down unless you hold the button the whole time. The remote wont' make it go down either. It begins to sometimes and retracts, but sometimes the light bulb just flashes (like it is obstructed). I tried replacing the wall switch and that did nothing. Help!
    May 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
    I have the similar problem + the light bulb is on all the time???
    HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
    WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
    ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
    ARE THE EYES WIRED CORRECTLY?
    ARE THEY AIMED AT EACH OTHER?
    YOU CAN GET THE FULL INSTRUCTIONS AT LIFTMASTER.COM
    THE MODEL # WILL BE DIFFERENT BUT THE INSTRUCTIONS ARE THE SAME LOOK AT THE MANUAL FOR MODEL 3280
    HOPE THIS HELPS
    Apr 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
    836 people viewed this question
    Top Chamberlain Car Audio & Video Experts
    Marvin
    Marvin
    cavs1
    James Steuber
    James Steuber
    Level 1 Expert
    Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
