Replacing ink cartridges.
Before buying replacement print cartridges, verify the correct part numbers.
The printer can operate with only one print cartridge installed. For more information click
here.
To replace a print cartridge:
1. Load a stack of plain white paper in the In tray.
2. Press the Power button to turn on the printer.
3. Open the printer cover.
4. Lift the print cartridge latch to the open position.
5. Slide the print cartridge out of the print cartridge cradle.
6. Remove the replacement print cartridge from its packaging and carefully remove the plastic tape.
Caution! Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad
electrical connections. Do not remove the copper strips. They are required electrical contacts.
7. Hold the print cartridge so that the copper strip is on the bottom and facing toward the printer, then slide the print cartridge into the cradle.
8. Push down on the print cartridge latch until it snaps closed.
9. Close the top cover.
The printer automatically prints a calibration page.
print cartridges
These print cartridges can be used with the printer.
l black print cartridge
l tri-color print cartridge
l photo print cartridge
Not all print cartridges may be packaged with your printer.
All print cartridges are not available in all countries/regions.
Hope this helps.
Have a good day.
Now this is really simple procedure. First you must determine the correct slot/holder for each cartridge; colour and black. To help you, in front of the cartridge area is a triangle symbol (your black cartridge goes here). then you have the pentagon/square symbol (your colour goes here). Now you simply hold each cartridge with copper panel (copper dot-like) away from you, hold it against its slot/push it in to the end and with your thumb, preferably, snap it up sharply. do the same to the second cartridge.
Here's a link to your User Manual. Go to page 36 and it will walk you through the process.
http://h10032.www1.hp.com/ctg/Manual/c00044028.pdf
