Question about Canon PIXMA iP1500 InkJet Photo Printer
Color fading my printer colors are fading although I just instuled a new cartridge.... please help
    Master:
  • 619 Answers
Hi , the printer are dried up need head cleaning twice then test print , if color of test print are complete color no spaces ,it means head are clean .
Posted on Jan 23, 2008
Why is my printer not printing the right color? its very faded
Is your printer set to Economode in the printer settings? It may be and so its printing at low quality.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
CANON PIXMA COLORS ARE LIGHT
I would manually clean out the printhead, I believe for your model it is a separate unit form the ink cartridge. Please follow these steps bellow.
First you will need to remove the cartridges, then remove the printhead assembly then mix some water and isopropyl alcohol in a 50/50 mixture. You can either use a cotton swab to rub the water and alcohol on the printhead or you can soak the inkjet printhead for around 2 to 5 minutes. This should loosen the dried ink. It may take a few attempts and requires patience. Dry it on a folded paper towel and reinstall it. Print a test page to check quality. If the documents are still printing with poor quality, repeat and soak the printheads for longer.
Let me know if that helped. I had the same issue and this resolved it for me.
Thanks
Bloomfield Connecticut Computers (BCC)
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_8bda69cf9239121b
Jan 13, 2014 | Canon PIXMA MX700 All-In-One InkJet...
No color even though new cartridge
The ink come directly from the cartridge in this printer. I would recommend running some cleaning cycles (if available) and sitting the cartridge on a damp piece of tissue for 15-30 seconds to try and get the ink flowing.
Failing this it is likely to be a duff cartridge, so please contact your retailer. These cartridges are a bit long in the tooth now.
Nov 19, 2012 | HP DeskJet 895cxi InkJet Printer
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
Black lines across the page
hi there,
unplug cartridges and check its heads are clear if not take a tissue paper and cleane it very gantelly, intall the cartridges and run cleanning test from printer properties.
Jul 11, 2010 | Lexmark X2600 InkJet Printer
Magenta cartridge not working despite being full
This happens due to Laser sCANNER Contamination.
Light Output that typically starts fading along the outside edges of the media. The first noticable color would be Magenta.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach eazily.
Aug 27, 2009 | HP Color LaserJet 2600n Printer
Color cartridge does not work - color faded. Just replaced AGAIN today - same problem
Remove it,replace it couple of times.
Run a nozzle and printhead cleaner check,
from your printer's properties, maintainance.
align too, just to be sure your setup correctly.
Check your printer settings for quality of the print.
there are various choices there for you.
Should be good then
Regards
Richard.
Apr 21, 2009 | Lexmark Color JetPrinter Z52 InkJet
HP 2605dn laser - color fading
HP has a list of troubleshooting steps you can go through for the HP 2605dn when you experience print quality issues.
Two specific things I would try from that list are:
  1. Clean the electrostatic transfer belt.
  2. Clean the printer paper path.
Good Luck!
*If you find the solution helpful, please rate it!*
May 15, 2008 | HP Color LaserJet 2600n Printer
Color is all wrong regardless of cartridge or cleaning.
Change the cartridges. Very very common problem with 4200's cartridges. From my own experience this is the only solution.
Dec 15, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
1,234 people viewed this question
old marine
old marine
