Question about Sony VPL HS10 Multimedia Projector
Blurred image from sony home theatre projector
I have a Sony VPL something projector in a 15' room projecting a 12' wide image on a wall that is painted with the proper screen paint etc. Worked great for 2 years. Now there is an oval blur several feet wide in the middle of the picture. Same blur with all movies, does not change with time. Tried new bulb and filter with no improvement at all of the blurred portion. I asked dealer and they suggested bulb & filter, then they said send it to someone for repair. The projector is on 8 hours / day, 3-4 days per week for the 2 years prior to this problem. Not sure of the model number, projector is at my office, but it sounds familiar to the model number listed below.
Thanks, Craig
    Problem Solver:
  • 17 Answers
Unfortunately an expensive repair or total replacement are probably your only real options. Electronically the projector is fine but your problem lies in the physical optics part of it. Either part of the lense assembly or the refraction array is likely damaged or at least very dirty. I wouldn't suggest trying to clean it yourself as this is a 3 LCD projector and all 3 must align perfectly after cleaning or you'll end up with seperated colors. It could also be one of the LCD's is damaged but from your description I don't think so.
I have a client that had the exact same issue with a different VPL model and it was cheaper to go out and buy a new projector than to fix it.
Posted on Jan 18, 2008
Noticed a yellow hue in the centre of the image projected by BOTH of my second-hand Sony VPL PX40's.
Bit of a common problem with Sony projectors of the era that they often had problems with fading and/or cracking of one or more the LCD panels - especially the blue ones for some reason, leading to the type of problem you are experiencing. No point in swapping components either as they will both have similar faults - although replacing an LCD in a video projector is almost impossible without the manufacturers jigs to mechanically align them afterwards anyway...
Mar 25, 2014 | Sony VPL PX40 Multimedia Projector
Vpl-hs60 projector diagonal is off
You should be able to readjust the picture by moving the projector physically till you find the sweet spot.
Mar 24, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Can only view image in a very dark room.
If you need it you can get the user manual on this link; check page 29 - brightness setting adjustment just to be sure this is not the problem. check page 36 - lamp mode - try high if not already set on it. Check page 42 - cleaning the filter - this can stop the projector functioning properly, but i don't think it's the problem in this case If the image is being projected exactly as normal, apart from the brightness, then the problem is most likely a failing bulb, despite the low hour count. Just possibly (but unlikely)there is a power supply problem that is not feeding enough voltage to the lamp, only way to tell for sure would be to either get a meter on the lamp terminals, which looks practically impossible with the lamp in place, (possibly will give a reading without the lamp, but the terminals may be disconnected from the power when the lamp is removed), or replace the lamp. Are there any flashing lights or error messages at all, does the projector seem hotter than usual, is the fan running as normal? could you actually see any error messages on the projected image if they were there? try really hard to read them if you think there could be something there. Try a different input source, unlikely problem but possible. Especially in smoky environments the lens can get quite a thick layer of grime on the outside - easily cleaned off gently with some vinegar and soft paper towel/soft cloth. This made enough difference on a similar one in a bar near me to give them 3 months more with the same bulb. Worth a try. If you need to source a bulb you need Sony LMP-E180 there appear to be no cheaper substitutes, you can get one direct from sony uk on this link; These lamps are often cheaper from the US even with postage, if you can find a dealer who will send you one, check this link for some ideas; I got a lamp for a similar sony projector sent to spain a few months ago, saving about $280!!! - I'll keep trying to find the details of the company I used, no luck at the minute. Hope this helps, post back if you have any more info :)
Jun 30, 2007 | Sony VPL-CS7 VPL-CS7 MMPROJ XGA 1800LUMEN...
How do I connect the Sony LCD VPL-CX63 projector to my desktop computer (not a laptop)? We can not get the image from the computer screen to project.
You probably have to lower the resolution on your PC before you connect the projector. The frequense also can´t be to hight. Start with 800*600 at first then on increase if it works.
Dec 09, 2010 | Sony VPL-CX63 LCD Projector
Dec 30, 2009 | Sony VPL CW125 LCD Projector
My projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Dec 07, 2009 | Sony VPL CS6 Multimedia Projector
Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
Jun 26, 2009 | Sony VPL-CX6 Multimedia Projector
Getting image to project
You are going to have to read the manual, and operate the projector as you read each section
Oct 16, 2007 | Sony VPL CS2 Multimedia Projector
I also have this same problem with my HS51A... With nothing on the screen you can see that the panel is physically shifted.
Aug 21, 2007 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony VPL HS10 Multimedia Projector Logo
243 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
