Question about Panasonic DMRES15 DVD Recorder
I HAVE DVR RECORDER
PANASONIC, BUT THE REMOTE CONTROL DOESN T WORK AT ALL, EVERYTIME WHEN YOU PRESS ANY KEY IN THE DVR SCREEN APPEAR ( SET 1) THE DVR WORK GREAT, BUT THE REMOTE
DOESN ' T. I ALREADY USE ( ENTER + 2 HOLDING FOR 10 SECONDS DO NOT WORK ALSO).
  • stwilc May 08, 2008
    Same problem. I did the +1 and +2 thing, but it didn't do any good. Also tried reseting logic by disconnecting the power from the unit and the batteries from the remote, but also no help.
  • luis lopez sanchez Sep 08, 2008
    my dvd ercorder dmr-es15. has a problem. leaves a message in the screen of the television set that says asi. pulse enter the tray outside and it united was put out. and in the screen of the dvd leaves U61. no longer hayo that to do. I need aid. and always the same thing says
Im looking for a remote control for it, you know where I can find it? thank you, for you help
Posted on Nov 28, 2008
Thank you I press ENTER and 1 for 20 seconds and my control is alive again..... thanks it work... :)
Posted on Sep 16, 2008
I too had this problem recently (display showing SET2). Tried unplugging, changing remotes, reading the manual (!), searching online. Found this site and THANK YOU! It didn't work the first time but I manually turned off machine, held down enter on remote, then held down 2 on the keypad of remote. I don't know how long I held it (10 seconds, 20 seconds...) but it worked.
Posted on Jul 09, 2008
I have had the same problem... 2 times, I just figured it out thanks to your post, try (ENTER + 1) hold it for 10 seconds, that should solve your problem. Hope this is of some sue to you.
Posted on Feb 02, 2008
I had the same problem. press enter, hold it down and press and hold 1 for about 10 seconds.
Posted on Jan 27, 2008
I had a new dvr added to my TWC cable services,but installer did not totally explain how to record or find recordings after taping. Can anybody tell me how to remedy this problem?
http://www.timewarnercable.com/en/support/faqs/faqs-tv/on-screeng/iguide/how-do-i-record-a-show-using-m.html
How do I record a show using my DVR and i-Guide?
There are multiple ways to do this:
  1. Press the RECORD button on your remote control while watching a program to begin recording. An overlay will appear on your screen to let you know you have started recording.
  2. From the TV listings grid, highlight the show you want to record and press the Record button.
  3. From any program information screen, highlight the Record icon and press the OK/Select button on your remote to schedule a recording. Follow the on-screen prompts for additional recording options.
Manually schedule a recording for a specific time or channel:
  1. Press the MENU button on your remote control then select the DVR icon.
  2. Or, if available, press the My DVR button on your remote control.
  3. Select the start time, end time and day that you want to record.
  4. Press Confirm.
  5. In the channel list that appears, select the channel to record from.
  6. Select Record to confirm your settings or select Recording Options for additional options.
and:
Video:
How to video DVR
Jul 12, 2016 | Televison & Video
The remote just says set 2 and does nothing
Does the TV screen say Set 2 or the display area on the DVD recorder? The original remote for the DMR-ES35VS doesn't have a screen. (If you are using a universal remote, I'm not sure how to reset the unit.)
The Set 2 indicates that the unit was set to listen to a remote on the second wavelength available on these remotes. Your remote needs to be set to the same wavelength. Press and hold Enter and then press and hold 2 (for about 2 seconds) on the remote to set it to this option. Press Return to move back through the menu or exit the screen. (Panasonic provided this feature for those with several devices so that each remote wouldn't control a nearby device at that frequency.) To get the recorder to respond to the remote, they must be set to the same range. To check, press the Functions button. Under Other Functions > Setup > Remote Control Code, you can adjust the wavelength that the receiver is looking for. (Use the up/down arrows to select a sub-menu and the Enter key to enter the sub-menu. Use the left/right arrows to select options in the secondary menu.) If the unit doesn't respond, try a different wavelength. (Press and hold Enter and then press 1 or 3. There are only three possible options for the remote/receiver.)
For a screen capture of this, see page 19 of the manual; it is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRES35V.pdf . An original remote is available from Remotes.com: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DMR-ES35VS&uuid=13262363222670 . It probably comes pre-programmed for Remote Code 1.
I hope this helps.
Jan 10, 2012 | Panasonic DMR-ES35VS
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
Dvr restart
WARNING: this will wipe out all of your recordings, all scheduled recordings, all series recordings (your series priority list), and all manual recordings!! Write down everything you can before you do this!
  1. The DVR should be turned on. Press CABLE, POWER to turn off the box.
  2. Immediately press OK/SELECT to bring up the diagnostics page.
  3. While on this screen, press the following key sequences press the counter-clockwise arrow (REPLAY on some remotes) 2 times, then press the MyDVR (LIST on some remotes), button 3 times then the live button 2 times."Clr" will appear on the LED display.
  4. Press OK/SELECT to proceed with the reset. The STB should now reformat the HD & then perform a STB reset and begin to reload your Cable settings and Time Settings from the Head End. It will then begin to populate the Guide data over the next 2 - 24 hours.
On some systems, the button press pattern may be 1-3-1, not 2-3-2 as above. This is true for at least the DCT 3416 I on Shaw.
Feb 17, 2011 | Computers & Internet
Remote won't work
According to page 15 of the manual, you should "Press and hold [ENTER] and the indicated number button at the same time for more than 2 seconds" This will work for SET 1, SET 2, etc. If you have lost the manual for the DVR/Remote you can download a copy at http://service.us.panasonic.com/OPERMANPDF/DMRES15-MULTI.pdf
Jan 02, 2010 | Panasonic DMRES15 DVD Recorder
Hi, when i press any key on the dvd recorder remote (panasonic dmr-e55) i comes up with remote dvd 1 everytime and wont do anything else, weve tried umplugging it 2 but that doesnt help, do u have any...
Very easy fix.
Your DVD recorder can be set up to accept remote contol signals on any one of three channels. DVD 1, DVD 2 or DVD 3. Your remote can be set up to send signals on any of these channels. You need to make sure your recorder and remote are set to the same channel.
Your recorder is telling you that it is set to receive remote control signals on channel DVD 1. This means your remote control is currently set for a different channel.
Assuming that you have a genuine Panasonic remote, do the following, On your remote press the "Enter" button and hold it down. Then press the "1" button at the same time for two seconds, then release both. This will change your remote so it sends signals on DVD 1 which will match your recorder.
Those clever people at Panasonic realise that you will be delighted with their products and will probably have several of their appliances in use. The different channels avoids switching all your Panasonic gadgets at the same time. Clever huh?
Best wishes
Dec 29, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR E80H Video recorder remote
While pressing [ENTER] on the remote control press the [1] button on the remote - that should change the remote's control code back to one.
Jul 28, 2008 | Panasonic DMR-E80H DVD Recorder
Sanyo DVR-DX600 Region Code
Could you pls try:
1. Remove DVD or video from the player.
2. Press the ‘Set-up’ button on the remote control.
3. Select the ‘System Info’ mode from the on-screen menu.
4. Using the remote control 10-key type in ‘1101′
5. ‘Region code’ should appear as an option on the ‘System Info’ menu. Initially the region code will be set to 2. Press ‘0′ on your remote control using the 10-keys to set to multi-region.
6. Press ‘OK/Enter’ on the remote control.
7. Finish by pressing the ‘Set-up’ button once more.
This was actually intended for a Sanyo DVR-V100E &HVRDX610 but I was made to understand should also work for DVR-DX600. This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Televison & Video
Set 1
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
Jan 14, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMRES15 DVD Recorder Logo
225 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
