I just recently purchased a G.E. front load washer and dryer. My washer would run a cycle then sit with 1 min remaining on the display. I know this is an estimated time but it would sit like that for a couple of hours. One day I got frustrated and unplugged the washer when it was sitting like that, thinking it may reset itself. Did I ruin my washer or is there a way to fix this problem?
  • 447 Answers
No you didnt ruin your washer, in fact that is the only way to reset the electronics. Just like the computer you are on, they sometimes glitch and lock up. Unplugging a washer doesnt harm it. It doesnt have a hard drive. If the washer continues to do this you will need to replace either the main computer or the display board.
Posted on Jan 18, 2008
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Siemens WFXD5201UC Front Load Washer won't complete cycle.
I am having the same problem with my washer. Did you ever get it fixed??
Mar 23, 2009 | Siemens WFXD5200UC Front Load Washer
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Time remaining stays at 1 min for 20 min
This may happen if using the Super-eco program.
It is designed to extend the washing time / cycle, but is less intesive in rotations. It's more a long gentle soak than a quick scrubbing action.
Thank you for using Fixya! If this provided a solution, please rate as such. Thanks.
Jan 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Display panel
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Oct 09, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
