Question about Gateway GT4022 PC Desktop
XP PROBLEMS I GET AN ERROR ON START UP FOR A VALADATE MY WINDOWS BECAUSE IT DID NOT PASS. HAD SOME 1 TO FIX COMPUTER AND IT JUST STARTED HE USED ANOTHER WINDOWS XP BUT MY COMPUTER HAD IT ALREADY HOW DO I REINSTALL WITH THE RIGHT KEY NUMBER
REformat your PC....that's It.... n_n
Posted on Jul 26, 2008
    Genius:
  • 1,226 Answers
If your windowsxp is license there is no problem about that because if your connected to the internet and in case this validation will pop up again you should validate it via internet. however if your windowsxp is not license you should provide one or you need an installation disk that have a correct cd key and did not need validation.
Posted on Jan 18, 2008
    President:
  • 317 Answers
At the windows login screen there should be a link or button you can click on and enter your key. Sounds like the person that fixed it didn't validate it. Did you install new hardware? If so, you'll probably have to call microsoft to validate.
I have a Dell XPS 419 and receive STOP: 0x00000024 (0x00190203,0x8AD31CA0, 0xC0000102,0x00000000) on the BSOD. Any ideas what it is or where to start?
Stop: 0x00000024 generally occurs due to the following reasons
1. The file system or partition structure is corrupted.
2. A driver compatibility issue exists.
1.Try boot the computer in last known good configuration. You may refer the link for steps: How to start your computer by using the Last Known Good Configuration feature in Windows XP: http://support.microsoft.com/kb/307852
2.Run chkdsk tool from Windows recovery console. You may refer the links for description of the Windows XP Recovery Console: http://support.microsoft.com/kb/314058
How to perform disk error checking in Windows XP: http://support.microsoft.com/kb/315265
May 02, 2014 | Computers & Internet
Error code 0x80070002
Reset the default security provider in Windows XP To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry:HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\ProvidersHKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
  4. Quit Registry Editor.
  5. Restart the computer.
  6. Use a system utility software like ReginOut to fix this problem without performing the above steps.
Dec 31, 2011 | Toshiba Satellite A55-S106 Notebook
My computer is stuck in hybernation mode
Hi wushuassazin:
1. What exactly do you see on the monitor screen when the computer starts?
2. Do you see any error message?
Step 1: We recommend you to start your computer in last known good configuration and check if the computer starts.
a. Start your computer and tap F8 key continuously to see advanced boot options.
b. Select Last known good configuration and hit enter.
c. Check if the computer starts.
Step 2: If the computer does not start, then check if it starts in safe mode
a. See Start the computer in safe mode
b. Check if the computer boots to the desktop.
c. If it boots, then restore the computer to an earlier time.
See How to restore Windows XP to a previous state
Step 3: If the computer does not start in any mode, then repair install using Windows XP disc
a. See Perform a Repair Installation
b. Once you've completed the installation, check if the issue persists.
Also use a system utility software like RegInOut to fix and avoid all such type of windows errors.
Hope this solution works for you.
Dec 25, 2011 | Gateway Computers & Internet
My vista is not performoing well .it dosent startup properly.only a black screen is comming.no msg is coming.it is only working in safemode.now i am in ubuntu
Resolution : Fallow method 1 or method 2 no data will be deleted.To resolve this issue, you must have the Windows XP CD-ROM. If you do not have the Windows XP CD-ROM available,
If you have the Windows XP CD-ROM, use one of the following methods. Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 A description of the Safe Mode Boot options in Windows XPIf you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.( In safe mode)
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
    For more information about how to use the Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base: 307654 How to install and use the Recovery console in Windows XPNote For more information about an error message that you may receive when you use the FIXMBR command, click the following article number to view the article in the Microsoft Knowledge Base: 266745 Error message when you run fixmbr commandWarning If your computer is infected with a virus and you use the FIXMBR command, you may be unable to start the computer. Before you use this command, make sure that the computer is not infected with a virus.
  4. If the primary boot partition is a FAT partition, use the FIXBOOT command from the Windows XP Recovery Console to write a new boot sector on the system partition, and then use the FIXMBR command to repair the master boot record.
Method 2: Repair your Windows installationNote Repairing your Windows installation may change the configuration of Windows. You may also have to follow this step if you complete all the troubleshooting in steps option 1 and the problem is not resolved.
  1. Use the Windows XP CD-ROM to start your computer. On the Welcome to Setup screen, press ENTER to set up Windows XP.
  2. Press F8 to agree to the license agreement.
  3. Use the ARROW keys to select the Windows XP installation that you want to repair, and then press R.
    Windows XP Setup repairs the installation files, Windows XP automatically restarts, and then the Setup program finishes the repair of your Windows XP installation.
  4. Follow the remaining steps to set up Windows.
    Note You must have your 25-character product key to complete these steps.
  5. As soon as this issue is resolved, make sure that the firewall is enabled, and then visit the following Microsoft Web site to reinstall the latest updates: http://windowsupdate.microsoft.com/
  6. Run a virus scan on the computer because problems with corrupted elements can be attributed to viruses.
Dec 26, 2010 | Computers & Internet
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
Error Code: 0x80070002
I think The default security provider in Windows XP has been changed loadTOCNode(2, 'workaround'); To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  3. Delete the following registry keys in the Windows registry: HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
Jun 02, 2010 | IBM ThinkPad A21m 2628 Notebook
I can't start my windows there is a error message
Well you need you windows XP CD to fix this problem. You have to boot to your Windows XP CD and repair the operating system. Any windows XP CD can be used to repair your computer. If there's none. Call the manufacturer of the computer and see if they can send you one.
Feb 10, 2009 | Microsoft Windows XP Professional
Victim of software counterfeiting
So you have installed windoes and input your COA sticker from Microsoft? If this is true then you can call them to get it validated. The number I found for you is (888) 352-7140. Resolved.
Dec 09, 2008 | Bose Companion 3 Computer Speakers
Continuous BLUE SCREEN after sp2 install.
After you upgrade your computer to Windows XP, you might receive the following Stop error message when the computer starts: STOP: 0x0000007E (0xC0000005, 0x804E518E, 0xFC938104, 0xFC937E04)
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
WUSB54GCx86.sys- Address 92D89498 base at 92D7c000, Datestamp 45c04cc9 Note The parameters and file names in this error message might vary, depending on the cause of the Stop error. The file name in the second line of the error message, WUSB54GCx86.sys, is an example of a driver file that might be causing the error.
This article discusses seven methods for resolving the problem. The first method is designed for beginning to intermediate computer users. The other six methods are designed for advanced computer users.
Because this article contains steps that involve restarting your computer, you might find it easier to follow the steps if you print this article first.
CAUSE
This issue might occur if a system thread generates an exception that the error handler does not catch. This exception can be caused by any of the following: • If this issue occurs after the first restart during Windows Setup or after Setup is complete, the computer might not have sufficient hard disk space to run Windows XP. • The computer BIOS might be incompatible with Windows XP, or it might have to be updated. • The video adapter drivers might be incompatible with Windows XP. • A device driver or a system service might be damaged. • If the issue is associated with the Win32k.sys file, it might be caused by a third-party remote control program.
Use the Windows Error Reporting tool loadTOCNode(2, 'resolution'); You can use the Windows Error Reporting tool to send information about the error to us and to obtain information about any available fix or workaround. Follow these steps to use the Windows Error Reporting Tool: 1. When the Windows Error Reporting window pops up on your computer, click Send Error Report to send the error report to us. 2. In the confirmation window that appears after you send the error report to us, click More Information. This helps you find any available fixes for the problem or information about how to work around the issue. 3. If a fix or a workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue. If you are not comfortable with advanced troubleshooting, you might want to contact Support. For information about how to contact Support, visit the following Microsoft Web site:
Method 1: Make sure that you have sufficient hard disk space loadTOCNode(3, 'resolution');First, make sure that you have sufficient hard disk space. The Stop error can be caused by insufficient hard disk space.
If you can use safe mode or the Recovery Console to start the computer, delete any unnecessary temporary files, Internet cache files, program backup files, and files that contain saved file fragments from disk scans (.chk files). You can also install Windows XP on another hard disk that has more free space.
If you cannot start the computer, go to the next method to update the computer BIOS.
Method 2: Update the computer BIOS loadTOCNode(3, 'resolution');If freeing space on your hard disk did not resolve the problem, the BIOS might have to be updated. Use the hardware and software vendor contact information articles that are listed in the "References" section to contact the computer manufacturer to obtain the most recent BIOS update.
Note When you update the BIOS, you might have to disable BIOS memory options, such as caching or shadowing, temporarily.
Method 3: Disable or update device drivers loadTOCNode(3, 'resolution');If you have updated the BIOS successfully and the problem persists, the video adapter drivers on the computer might have to be updated or disabled. Follow these steps to troubleshoot the video adapter drivers: 1. If a driver is listed by name in the Stop error message, disable or remove that driver. • If the error occurs during the startup sequence and the system partition uses the NTFS file system, you might be able to use safe mode to rename or to delete the faulty driver. • If the driver is used as part of the system startup process in safe mode, you must use the Recovery Console to start the computer. 2. If the Stop error message does not indicate a specific driver, update the video adapter drivers to the latest versions. 3. Disable or remove any drivers or services that you recently added. 4. Check the Microsoft Hardware Compatibility List (HCL) to determine whether the PCI devices in the computer are compatible with Windows XP. For information about the HCL, visit the following Microsoft Web site:http://www.microsoft.com/whdc/hcl/default.mspx
Method 4: Remove unsigned driversIf you have updated the video adapter drivers and the problem persists, or if you cannot start Windows in safe mode, the problem might be caused by a different, unsigned driver. Remove all drivers that are not digitally signed by Microsoft. For more information about how to do this, click the following article number to view the article in the Microsoft Knowledge Base:
316434 (http://support.microsoft.com/kb/316434/) How to perform advanced clean-boot troubleshooting in Windows XP
Method 5: Remove all third-party drivers loadTOCNode(3, 'resolution');You might be unable to determine which third-party driver causes the error. If removing unsigned drivers does not resolve the issue, try moving all third-party driver files from the %Windir%\System32\Drivers folder to a different location. Follow these steps to move the third-party driver files: 1. Use the Recovery Console to start the computer, or start the computer from a different installation of Windows if you have performed a parallel Windows installation. 2. Create a temporary folder to hold the driver files. For example, you could create c:\DriverTemp. 3. Move all files that do not have a creation date for Windows XP of 8/13/2001 from the %Windir%\System32\Drivers folder into the temporary folder that you created in step 2.
Caution If the computer relies on third-party IDE or SCSI controller drivers for correct operation, you must identify those driver files and then leave them in the %Windir%\System32\Drivers folder. 4. Restart the computer. 5. Continue the Windows Setup program. You can add the driver files back to the computer one at a time to identify the faulty driver.
Method 6: Remove third-party remote control servicesIf you still have the problem after you use the previous methods and the Stop error message contains the Win32k.sys file name instead of a driver file name, the problem might be caused by a third-party remote control program. To remove the service, use the Recovery Console to start the computer and then delete the third-party remote control service file.
Oct 24, 2008 | Intel Motherboard
Gateway GT4022 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
