Question about Asrock M266A Motherboard
Memory installation i change my 128ddr pc2100 ram into 512ddr pc3200 in did not work but when i put back my 128ddr ram the computer doesn't start, and there's no beep.
    President:
  • 2,351 Answers
Check your manual pg. 11 section 2.5. The 168-pin RAM go in the black slots ONLY. The 184-pin RAM goes in the blue slots only. Worth a check! Luck.
Please vote.....
Posted on Jan 18, 2008
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
I want to extend the RAM memory on my NEC computer. The motherboard is a GA-8SIMLNF Rev.1.1. It has two memory slots and presently one slot is occupied with a PC2100U-20330-A1 256 DDR 133 CL2 memory. I...
Check your manual (Gigabyte will have the manual on their website), to make sure your motherboard can handle 1Gb of Ram, or more. Generally in my experience, medium aged motherboards handle 1GB per slot, max (mine uses PC3200, not PC2100, and will take up to 4GB in its 4 slots).
You'll want PC2100 ram (easily searched for on http://www.newegg.com), either in 2x512MB sticks, or a single 1GB stick for your open slots (bringing you up to 1.25GB).
Mar 01, 2011 | Intel Motherboard
Hi Dear ; When I install memory RAM of 1.0GB .. get ERROR
Cant find your motherboard on the support page, is the memory your trying to install the same speed?
Jul 16, 2010 | Intel Computers & Internet
If i change the ram stick will my pc reconise it
Yes.
Provided,
1) It is no more than the maximum amount, for that ram memory slot.
2) Adding it, will not go over the Maximum Total Amount for the motherboard.
If this pertains to an Acer Aspire T135 desktop computer,
A) The Maximum Total Amount is 2GB.
B) The Maximum Amount for Each ram memory slot is 1GB.
C) PC3200 is the best you can use.
DDR Sdram at 400MegaHertz. (400MHz)
[It can also use PC2100, and PC2700.
DDR Sdram at 266MHz, and DDR Sdram at 333MHz, respectively ]
Once you install the ram memory, BIOS should automatically find it.
If you are only going to use one ram memory module, be sure to put it in Slot 1.
The Processor reads ram memory in Slot 1 first.
[Slot 1 is closest to the Processor.
It may have DIMM 1 printed on the motherboard, next to Slot 1 ]
Jun 21, 2010 | Acer Aspire T135 PC Desktop
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
What type and how much memory can i put in the MB MS 6577 Ver 4.1?
1GB Of PC2100/PC1600
According to:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Apr 24, 2009 | Computers & Internet
I think I have the wrong memory installed.
You shouldn't see any problems as your computer supports up to PC3200. Basically it is backward compatible so your computer will support PC3200 and all the lower numbers, such as PC2700 and PC2100.
Mar 28, 2009 | FIC AM 35 Motherboard
Installed a new memory now computer won't boot up.
u just bought the wrong type of memory take the chip out of ur pc to best buy or a good computer store to help u buy the correct memory
Nov 24, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
How much ram can i install on a hp compaq d220mt?
Laptop Computer Memory Desktop Computer Memory Printer Memory Memory Applications All data processing and execution takes place within the memory module(s). The program's directions are replicated into memory from a hard drive, external drive or from a network. The processor then extracts the directions from the memory and puts it into the circuit for analysis and execution.
Memory is so important that it cannot be wasted. RAM is allocated by the operating system and programs, and then released when not needed. Errant applications can grip RAM and not release it, which results in a diminishing amount of memory available as you load and use more programs.
If you could actually look into memory, you would be astonished. By watching how much and how quick data and commands are written in and out of it each day, you would realize it is a marvel that it works so we
UpgradeComputerMemory.com is here to help you speed up and breathe new life into your computer by adding more RAM memory! We have hundreds of relationships with different manufacturers and carry all major computer memory brands. This includes Dell Memory, HP Memory, Samsung Memory, Micron Memory, Toshiba Memory and many, many more. We can cut through all that computer jargon and provide you with the part that will work each and every time. Our 100% guaranteed compatible RAM memory upgrades are available for more than 21,000 different computers, laptops, servers, printers and other electronic device.
Jan 15, 2008 | Computers & Internet
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
Asrock M266A Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
