Question about Samsung DVD-VR357
Connecting DVD VR357
I am trying to connect my new Samsund DVD VR357. Does it need to be connected to the TV and my satellite box? How should it be connected? I have DirectTV and a Hitachi Plasma TV. Please help?
  • Anonymous Feb 14, 2008
    We bought a 357 and have a samsung lcd tv. Can play dvds and videos but cannot record from the tv so we think we do not have it connected properly. We have hd cable going between tv and cable box and the other portion of hd cable going from tv to dvd player. Have red, yellow, white cables going form dvd into side of tv. What are we missing?
  • 440 Answers
Direct to tv always best picture ok hdmi then sound from tvs digital outputs to input on your digital reciver ok
Posted on Feb 10, 2008
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Dec 29, 2010 | Televison & Video
Samsung VR357 will not record
Check if the record lock of the tape has not benn removed..
Mar 19, 2008 | Samsung DVD-VR357
I need help connecting tv to DVD player VCR and satellite box
Connect as following
1. Set top box - RF cable from STB to antenna socket on TV.
2. DVD player output to Video1 on TV
3. VCR output to Video2 on TV.
May be you can route VCR through the DVD player or viceversa. That you can see and try on ground.
Sep 28, 2010 | Haier TN201AUV 20" TV
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Connecting TV and Receiver Amplifier
you will have some line loss (decreased audio signal) at the stereo
you may pick up strange noises, as the 50 foot wires are antennas that will pick up stray signals if they are present
try it, then you will be the expert, as you are in 'uncharted waters'
Jun 13, 2009 | Samsung DVD-VR357
Dvd disk will not play
clean the lence with the cotton. if it is not come change the lence strip wire.the last thing is chane the spindle moter and then lense.
Thats it
Nov 06, 2008 | Samsung DVD-VR357
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
Toshiba VCR/DVD Recorder Combo - Problems connecting it to system
I was able to connect to my cable box. I used RCA (yellow, red, white) cabling. I connected the Video Out on the cable box to the Video In on the DVD/VC (to the DVD VCR cabling section). I then from same section used the Video Out using RCA Cabling to the the Video In connectors on my Phillips LCD TV. That left only to connect the TV to the cable box using regular TV coax cable. Everything works, although I am going nuts trying to dub from VCR to DVD-R or +R discs.
May 21, 2008 | Televison & Video
How To hook up vr357
Hi, You use the video and audio 'out' from your cable box to the 'in' on your Vr357. You can use s-video, component video cables or the av cables that came with it. You can use your HDMI cable from the VR 357 to your television. That will be for upconvert DVD watching. The cable box connection will still go from the box into your television. Hope that helps.
Jan 18, 2008 | Samsung DVD-VR357
How to record ?
I don't know a whole lot about electronic equipment, but I've never seen anything connected in so many ways at the same time. Maybe the antenna and one other type of connection. The different signals from all the connections are probably confusing each other. I would try one connection at a time to see if the problem improves. Good Luck.
Dec 16, 2007 | Samsung DVD-VR357
Samsung DVD-VR357 Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
