Question about Sony StylePro SDM-S73/B 17" LCD Monitor
Turns off I bought a monitor on E-Bay recieved it today and plugged it in and it came on, literally for a second , I saw the screen and it went out. I tried it again turned it on saw the screen and it turned right back off. If it's something simple I'll try and fix it myself if not I have a dipute already going with them on recieving something that was broken. Thanks!
  • ChuChu01 Jan 19, 2008
    This is ChuChu01 and the monitor that I have is a Sony SDM-S73/B I hope mine is an easy fix.
  • stephenhat May 11, 2010
    i have the same problem - have checked dry joints - all ok there
    maybe power capacitor - 120uf on power supply - any ideas anyone ??
    Sniper:
  • 114 Answers
I had the same problem with that model of lcd panel, the problem I found was the VR was defective, labeled VR2 on the power board assembly. I resoldered the connections to the VR and it's working fine now.
Posted on Jun 07, 2008
  • 38 Answers
You bought a monitor with a bad inverter board or CCFL backlights that are drawing to much current. This is a typical problem with many LCD screens after a few years of use. It is repairable but requires skill and knowledge of this type of circuit. If it is an HP F1703 or 1503 it may just be a cold solder joint. Supply the make and model and I will be able to be more helpful. Some of these inverters are easy to fix others very difficult.
Posted on Jan 18, 2008
I`ve just bought and recieved today an Acer M3800 Desktop. having connected to my existing Tiny L157 LCD 19`` Monitor I am getting a no signal message on the monitor when the Pc has started up. I swapped...
Howdy, you will have to go into the video settings and select an external monitor. It's a little annoying at first with a laptop, but it gets easier with repetition.
Regards, farmerbear
Sep 10, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I've had my monitor for years with no problems. Today, when I turned on my computer, the monitor flickered. Then the screen went black, and the power button began blinking (green). When I turned it off...
A couple of things to check. First make sure that all the connections are in place. That is, the one at the PC and the one on the back of the monitor. Second - Make sure that the video card is seated correctly in the PC. Third - Replace the monitor cable. Fourth - Check with another monitor, if possible.
Mar 27, 2010 | Dell E153FP 15" LCD Monitor
Monitor blacks out after few seconds
Since you opened up the PC the first thing to do would be to make sure the graphics card (if it is a standalone card) is seated properly. Remove it, blow out any dust, and re-install it. If that does not fix the problem, or if the graphics are built into the PC, try getting a cheap video card (or borrow one from a friend) and that should fix the problem, since you have ruled out the monitor as the problem.
Also, it could be a problem with the power supply. I'd chase down the graphics card side first though. If that doesn't work, try the same procedure with the power supply.
Note: I have run into instances where an AGP slot got "zapped" by someone opening the case and not taking proper static precautions, so be careful, always unplug the PC and ground yourself to the case before touching anything. If you try a video card you know is functioning and it still doesn't work, pick up a PCI graphics card and see if that works.
Feb 06, 2010 | Computers & Internet
Sign of old age?
it is a problem with CRT screen.you can checked it from service center.
Dec 11, 2009 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
I plugged it in and the screen came up for a second and then went black. I turned it off and turned it back on, the screen came up for a second then went black again. What could be wrong?
is the cpu running ,, with connection to monitor,, you can try restart,, and go to display properties,, screensaver,, there power button and change the settings,,,
Sep 27, 2009 | Dell E173FP 17" LCD Monitor
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
No Signal message displaying after screen goes black
Try loading drivers for the LCD monitor.Right click empty part of desktop>>Properties>> settings It should show monitor name instead of plug and play monitor on ---- Video board.Go to Advanced>monitor>driver on this screen.
Samir
May 06, 2008 | Acer AL2017 20" LCD Monitor
Sony StylePro SDM-S73/B 17" LCD Monitor Logo
139 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
