Back to:
Tags:
Fellowes PS60C-2 Shredder
Not feeding (by 2 users)
posted by lgwork on Jan 18, 2008
Hi I do not know what happened prior - business owner was feeding paper it but the bin got very full. Was asked to empty - have done and removed all paper from the cutter but there is no movement at all. Lights are on but that is all. Can you help please
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 20, 2008
Feeds, then stops feeding, I pull paper then it feeds again, then stops feeding, pull on paper, thenfeeds again. Loud metal noises.
Have cleaned shredder completely - disassembling - same problem remains.
Best Solution
posted on Feb 22, 2008
FixYa! (100)
fellowesrep
Rank:Guru Guru
Rating: 87%, 115 votes
usually this indicates that the bin has not been properly put in place. On the inside of the waste basket there is a plastic piece that fits up into a slot on the shredder head This is our safety interlock. If plastic tab is bent or broken machine will not run without safety interlock engaged.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Not feeding:
I don't want to Accept this solution
Can you Help with these Shredders problems?
Shredders
need help can't aford to buy another one
Shredders
My shredder will not feed correctly. When I place paper in...
Shredders
I need the second step-up gear. (the last coaxial gear...
Shredders
I can only feed a few pages at a time before all the...
gears has free play and the shredder is cuting the paper...
Loading problems.
Repair Service
Find Shredder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
