Question about Maytag Atlantis MAV6000 Top Load Washer
Just hooked up and it won't keep water
I got this washer from my parents who had been using it for a month. It worked fine for them but I'm having a problem.
When I turn it on it starts to fill up with water but the water wont stay in the washer. It just drains when filling up? I don't know whats going on? Any help would be great. Thanks
  • 447 Answers
The drain pipe is one of the following
a) shoved wayyyyy to far the drain pipe
b) lower than the water in the tub
c) clamped tight to a drain line
Posted on Jan 18, 2008
ProForce PWC102350 2,350 PSI 2.3 GPM 163CC MagnaForce Gas Powered Pressure Washer will not start
If you have compression then the first thing you check is for spark. If you have spark then you move on to the fuel system. You will have to pull off hoses at a couple of points to see if gas is at the carb and further along. If it is the carb then a simple carb kit will work.
Apr 13, 2014 | ProForce PWC102350 2,350 PSI 2.3 GPM 163CC...
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Sony KDS-55A2000. bought 1/07. replaced bulb 2/08. gave tv to parents 11/10. worked fine until last week. 1 on screen message, temperature warning (they checked all vents-everything clear and 1' away from...
you will need to check the fans are all switching on when you turn the tv on, it might be one of the fan sensors that has gone bad, the tv wont turn on if it detects that the fans or a single fan is not working. I have not worked on this particular set , but that would be the first place i would look, if you find a fan is not firing up and if you have a multimeter, then check to see if you have a 12v voltage going to the fan, an easy way of rectifying it is to run a wire from one of the other working fans to the positive of the fan that isnt working. This would at least eliminate the fan as the culprit, if the tv starts up normally then the problem lies in why the fan is not receiving power. I ran a tv using this method for over 8 months before it died, from other problems i might add , not the fact i bypassed the fan power circuit.
If you found this info useful please take a moment to vote for me
Mar 30, 2011 | Sony KDS55A2000 55" HDTV
Sishwasher not used for months. Now motor only
Disassembled dishwasher. Some plastic scraps had shredded and wound itself around the pump impeller axis. It was preventing the motor from turning. Upon removal diswasher again worked fine.
Oct 22, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Parental Control Lock password Spectra KT2313
default passwords are often 1234 or all zeros that would be a good starting point
Sep 08, 2017 | Spectra KT2313 Combo
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Won't spin all other functions work properly
hi thanks for the question the washer does not spin to pump the water out first it has to pump the water out in your case i would check the drain hose make sure theres no obstruction thanks the appliance doc
Sep 06, 2008 | Maytag PAV2300 Top Load Washer
HOTPOINT aquarius WF541G
most likely suspect is the heater. undo wires from heater and see if fault persists. if not, heater is down to earth and will have to be replaced.
another possibility is a leak causing some of the wiring to be wet
Jun 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
