Question about Uniden Cordless Phone
Change/add #'s in Memory
Uniden 900 Mhz cordless phone w/ans mach. Have some stored numbers in memory that I need to change. And want to add additional numbers. Only buttons on handset are: Redial/Pause Select Delete/Channel Mem
I can bring up existing stored numbers by hitting Mem, scrolling to #, and hitting Talk. But cannot change or add new numbers. HELP!!
  • flotsam900 Jan 21, 2008
    Although I couldn't find the model # on the base, as described, I was able to view the manuals until I found a phone similar to mine. The instructions worked great! I am now able to update the memory - thank you so much!!!
    I think my phone is too old to even have a model # the way the current units are labeled. None of the numbers on the phone matched anything in their list.
  • Anonymous Mar 20, 2014
    I am holidaying in Australia and trying to call a friend in the UK. I need to know what numbers to put on the fron of the number I have and which numbers to remove. We are both connected with Lycamobile
  • 86 Answers
Find your model number and then click this link to download the manual
Manual page
Posted on Jan 20, 2008
Lost my manual. Could you describe how to change an existing phone number which is stored in the memory. ( EZAi 2997 phone.)
Phonebook instructions begin on page 12 of the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/EZAI2997om.pdf
Apr 03, 2011 | Uniden DECT 6.0 Cordless Phone ID
I need to set and rec/ ever thing
I have put a new battery in my unden 900 MHZ and don't have a manual anymore to tell me how to enter phone numbers in "memory".
May 19, 2009 | Uniden Cordless Phone exai398i
Lost manual
How do I change phone from pulse dialing to tone dial.
Thanks
Rjfawcett52@yahoo.com
Apr 22, 2009 | Uniden Cordless Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Unable to Store Phone Numbers
The store memory function is very similar to this phone in the EXA series phone made my Uniden.
See the instructions to store/delete/add numbers in the manual below on page 22.
http://www.uniden.com/pdf/EXAI2248Iom.pdf
hope this helps
- Pete
Jan 31, 2008 | Uniden Cordless phone EXS9950
Change ringer from lo to hi
Do you know the model #? If so, you can get the owners manual from the the uniden website. Here is a link to the page so you can look for your specific model number. Just click on your model number and it will load the pdf format of the owners manual.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Nov 27, 2007 | Uniden Cordless Phone
Programming a number for memory
Memory
Store up to ten 20-digit numbers in memory for quick dialing.
Storing a Number in Memory
1. Make sure the phone is OFF (not in TALK mode).
2. Press the MEMORY button.
3. Press a number (0-9) to store the dialed number in that memory location.
4. Press the MEMORY button again.
5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm.
6. To enter another number in a different memory location, return to step 1 and repeat the process.
Nov 03, 2007 | Uniden Cordless Phone
Programing the memory numbers
http://www.uniden.com/pdf/EXI2960om.pdf
Aug 31, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
439 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
