Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Seems like no power
I attempted to start my dishwasher and there are no lights, no sound, nothing.  As if there is no power to it.  However, we checked the wiring with a volt meter and it is getting 120 volts.   Is there a reset button somewhere?? Ctrl-alt-delete? Reboot?
    Genius:
  • 1,003 Answers
CHECK SAFTEY INEtRLOCK SWITCH THIS IS OPERATED BY DOOR HANDLE
Posted on Jan 18, 2008
6ya staff
SOURCE:
Won't turn on
Try just pressing the selection pad, without pressing start/cancel and close the door. That has worked for me a couple of times.
May 05, 2010 | Frigidaire Professional Series 24 in....
My dishwasher will not start. The 3 second button light is on and when I press it nothing happens . I try pressing any other button and nothing works
It sounds like you have "locked" the dishwasher. This was an added feature that most people never wanted since it only seems to be set by accident.
Try pressing the 3 second button and holding it down for at least three seconds. This should turn the light off. Drove us nuts the first time it happened. If it doesn't turn off then I guess it is broken.
Jan 03, 2010 | Maytag MDB7100AWB Dishwasher
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
My dishwasher wont start
Sounds like you need to check for power to the unit. Access is at bottom of dishwasher under panel. Next you will see the wiring coming into an enclosed electrical box. you will need to get to wires and check voltage on black hot wire to neutral with a voltage meter. If you have power but still doesn't work then at least you know the problem is with the unit and not the incoming power.
Jul 24, 2009 | Dishwashers
Hi!
Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Please see this picture of what the dishwasher switch looks like.
Please rate this solution as Fixya if found useful.
Please ask for any clarifications.
Thanks
Rylee
Mar 13, 2009 | Frigidaire Dishwashers
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to [email protected]. I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Laptop toshiba m35x attempts to power up but stalls
It sounds like video card problem. Bring it to a repair shop.
Dec 11, 2008 | Toshiba Satellite M40-S417TD Notebook
Dishwahser won't start, start button won't light
I took the door apart, removed the control board, which I had expected to replace. I disconnected the ribbon cable that connects the control panel to control board cleaned the connections and reassembled everything. The dishwasher has been working since.
Jun 16, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Aug 05, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
222 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Vitally Alcher
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
