Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Problem with picture
Picture stays for a second but the turns blank. Volume is ok
  • mr-ed-nc Jun 29, 2008
    I have a timing problem when using the remote "System" button to turn on the DVR (from cable co) and the HD TV. The TV seems to turn on too soon and shows the picture for a couple of seconds, then goes blank with sound only. The cable guy replaced the HDMI connection with component cables, but this didn't completely solve the problem. So I'm using HDMI again, but have added the VCR to the components to turn on, to delay turning on the TV. This works if you hold your mouth right and keep the remote aimed at the cable box longer before aiming it at the TV. The problem still occurs sometimes. Should I try eye of newt or something?
  • 64 Answers
Im just taking a long shot guess here but im guessing you have it hooked up to a DVR from your cable company via DVI cable? its coming on for a second then going away 5 seconds later.. cause the tv/monitor doesnt have HDCP (HD copy protection) the cable company's DVR's require this on digital video media connections. Same thing happened when i hooked my viewsonic 20.1 in lcd monitor to my DVR from Cox communications. got picture for about 5 seconds then nothing.
Posted on Jan 18, 2008
  • 143 Answers
Sounds like bad connections on inverter board
  • 106 Answers
Most likely it's the LCD panel assembly failure. Either the inverter board or scaler board.
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
The tv turns on ok but the picture goes blank after 10 seconds or so the sound stays on
Plasma or LCD? Make/Model? Any blinking lights?
Try swapping HDMI inputs first and follow up.
Jul 01, 2010 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
LE40R74BD VOLUME OK BUT BLANK SCREEN
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swolled on top and are easy to solder in cost about $1 EACH
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Blank screen
lamp is burned out cost around 200 dollars. easy for comsumer to replace them self. dont get a generic lamp
Jun 04, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
TV picture blanks out, the restores
your tv has a loose board problem, its either in main board or CRT socket.
Apr 10, 2008 | Quasar SP-2719 27" TV
174v monitor not weorking
check power section.check pf capacitors in this section for ok or replace them.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 24, 2008 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Picture issues
a short grid with an internal cathode in the CRT
Sep 02, 2006 | Toshiba CF32G50 32" TV
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
233 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
