Question about Microsoft Xbox 360 Console
No Video, but sound
I recently received the above mentioned from a friend. the system boots up and you hear sound, but no video. Is this an easy fix or his it a boat anchor now?
This problem has been talked about much in the following area: http://www.fixya.com/support/t260067-xbox_360_no_video
Looks like there is no real fix, only the "towel" trick has done anything for a few.
Posted on Jan 18, 2008
Sony dh800 transformer buzzes when warm, you can hear it on 0 volume and it sounds a little like the largest transformer. please help.
sony dh800 transformer buzzes when warm, you can hear it on 0 volume and it sounds a little like the largest transformer. please help. same problem as above
Apr 18, 2011 | Sony STR-DH800 7.1-Channel Audio Video...
How do I connect my Yamaha RX-V463 surround sound system to an analog tv? The tv only has the three RCA jacks for audio and video. the RX-V463 has many jacks, and the manual is no help. the manual does...
Actually, the Quick Start Guide on page 6 of the manual shows the TV connection.
Consider that the TV is simply a visual element in your entertainment system and the rest will sound easy.
Run a single RCA cable from the receiver to the TV's Video IN so you can use its menus and view whatever video comes into the receiver.
Manage whatever audio you want to hear in HI-FI directly from its source to the receiver and NOT washed through the inferior audio electronics and speakers of the TV.
Jul 18, 2010 | Yamaha RX-V463 Receiver
When I hit power button nothing lights up but I hear the subwoofer power on but still no sound. It's as if it wasn't getting power.
Try disconnecting everything from the back of the system and unplugging it form the wall for a couple of minutes. Plug it back in and try poering it on. You may google search "diagnostics boot" or "error boot" with you model number and see what comes up. There is a fuce inside you could check, usually to the back right on Yamaha receivers. This doesn't sound likely due to your subwoofer sound though....maybe.
I bought about 70 receivers that were last years models from Yamaha, Denon, Sony Bravia, etc. Most worked but some required fixing. Some where easy as fuses, blown capacitors (visually), then some are still in my storage LOL. I hope this helps. By the wy, you can always purchase a repair/diagnostics manual that repair shops use with diagrams and trouble shooting tips for your particular model.
GOoD luck
Jun 30, 2010 | Yamaha RX-V520
3 beeps on boot no screen and boot stops
sounds like the motherboard trying to give you an error code. search beep codes for the type of motherboard you have and then you will get a possible cause of the interruption.
my friend once gave me an old ibm that had a beeping sound preventing it from booting. i googled ibm beep codes and learned that it was a video card error. i swapped the video card and problem solved
Jul 23, 2009 | Intel D850MV Motherboard
I recently had my ps3 hooked up to the tv via the hdmi cable. Now i have taken it to my friends who does not have have hdmi so i connecting the three cables to the tv but have no picture or sound, why and...
Easy Solution,
Make sure your PS3 is connect and powered OFF.
Hold down your power button for 5-6 seconds until you hear the second beep.
That's it! Your video settings have been reset.
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
PT-52LCX65-K Panasonic rear-projection LCD No Sound
My panasonic did the same thing. turns out my coaxial cable hooking up the cable from the wall was bad. Once i unhooked it from the wall, the sound popped. I wiggled it a little on the receiver end on the wall and got sound. So try replacing your cable box cord and see if it fixes it.
Dec 15, 2008 | Panasonic PT-52LCX65 44" HDTV
No HDMI output with Panasonic SC-PT950
Change the video out settings from your system
Dec 10, 2008 | Sony DAV-S400 System
Hey sori ive lost my sounds system on my computers
Friend there are several possibillities to this problem and we'll discuss it one by one.
The first possible problem is that your operating system might be damaged by a virus that is why your sound system doesn't work. The solution for this problem is to have an updated anti-virus program on your computer and clean your computer with this anti-virus program. After you have done this procedure, you have to install a software that is compatible with your sound system or if you have a sound card on your computer use the software that is packaged along with your purchased sound card have it installed. After doing this procedure try to connect your sound system to the output of your computer usually there are holes or terminal in your computer that is exactly suitable to your sound system's jack and make sure that you connect to the output line. If this doesn't work install a media player to your computer and repeat those procedures mentioned above. In installing those software it is easy just follow the instructions and read carefully the images and characters presented by your computer screen.
Thanks! I hope i've solved your problem
May 26, 2008 | Audio Players & Recorders
No display
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
39
Apr 09, 2008 | Intel Motherboard
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
