I have a Toshiba 42inch LCD TV, model # 42LX196 that is just a little over a year old. The picture went out suddenly, and would only come back after unplugging and re-plugging in the TV. This happened several times over a couple of weeks until it now will not come on at all. We still get sound, but no picture. (It's the same from the DVD player and Wii, which are on different inputs.) We had a Sears repair person come out, and he indicated that the "display was bad", but he did not open the TV or check anything with instruments; that was his opinion based on observation. He may be right, but I would like a second opinion before chucking a $2000 TV we just bought a little over a year ago. Thanks.
    Brigadier General:
  • 6,966 Answers
Based on your post/description, your first step probably would be to determine the TV's fault: backlight, video, LCD panel or something else
All LCD TVs uses several CCFLamps as backlight. These are similar to the household tube florescent lamps. They are however powered by an inverter rather than the mains. To be able to determine if your backlight (or the inverter) is defective, you need to run the TV normally (albeit you can't see anything). Play a DVD or something. Get hold of a flashlight. Increase/Press the volume control of the TV (remote or panel) while shining the flashlight on the portion where you normally see the volume level indicator. Angle the flashlight obliquely to the surface of the display. Try to see if you can see some semblance of the volume level. it would probably be of help if the room is darkened a bit.
If you can see the volume level indicator, then your TV's problem is with the backlight and/or the inverter. Since you have a 42 inch, chances are your unit do have several lamps inside and very rarely (if ever) does it happen that all go dead at the same time. That would leave us with the inverter which is a high frequency high voltage power supply that provide the juice for the CCFLamps.
To check and repair the inverter, you need to be comfortable and familiar with electronic circuitry/components, use of a DVM< and a soldering iron. You need to check if DC voltage is coming in and high freq/high ACV is coming out. More often, inverter problems are overheated capacitors which would be indicated with blistered tops of the capacitor can.
IF on the other hand there is no dim image of the volume control level using the flashlight, then the issue could either be the video processor or the LCD panel itself.
The above of course would require that you open the LCD TV and do diagnosis/voltage checks of a live set.
If you are not comfortable with this, perhaps you would be better off seeking the services of a qualified professional.
Offhand, if the problem is with the CCFLamp, inverter, or video processor then it might still be worth having it repaired. If it were the screen, perhaps you have to consider the downtime and cost of repair.
Another consideration would be to find a tech who would be willing to do component level repair rather than board replacement.
Hope that this be of help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Posted on Jan 18, 2008
    Scholar:
  • 128 Answers
I think you should call Toshiba and ask them for assistance. I am no expert on TV's, but i think that would be your best bet on how to repair and found out what happened to your TV. Call them at 1-800-631-3811. Hope this helps. :)
I have a 3 year old Toshiba Regza model#40XV645U..all of a sudden the screen went to no picture..there is sound and its as if the picture is lying beneath a very dark blue screen w/ a very thin band of the...
Breaking down after 3 years is about right for LCD TV. It sounds like the T-CON board has gone out. Does the on screen menu look normal?
Learn about failed T-CON/LCD panel here and also read my guide to understand more.
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 04, 2011 | Toshiba Televison & Video
47" plasma 1080p ... screen went black , sound
Plasma TV's have a shelf life. By that I mean the screen is only good for so many hours depending on the model. Most likely, you have burnt out the screen and the set will need to be replaced. The good news is, plasma TV's used to be better than LCD but that is no longer the case. You can get a very high quality LCD TV for a very low price now. Also they use a fraction of the power and don't generate all of the heat of a plasma.I'm sure this is not what you wanted to hear but the reality is that ALL plasma TV's do this eventually, and it is something that most salesmen back in the day didn't bother to tell customers. If you have an extended warranty, you may be able to get it replaced.
May 05, 2011 | H&B HP5500V Plasma TV
My Toshiba 42lx196 will not power up and has a flashing red light that flashes 3 times then off then again and again
I have the same model and the same problem. I was watching it when I heard a loud "pop" and the screen went black and got no response from any controls. I paid $50 at a repair shop to tell me it was the power supply board and would be an additional $275 to fix. I chose to buy another tv but am searching for the part. Here are part #'s - 75003371, PE0071G-1. Some online stores have carried it for anywhere from $70 to $200. The cheapest I have found in stock anywhere is $150. Just google those numbers.
Mar 08, 2011 | Toshiba 42LX196 42 in. LCD HDTV
My 3 year old Proscan 42" LCD TV picture suddenly
On the far left and right inside the back on panel are inverter boards. Replace or look for capacitors buldged, swollen, or cracked on their tops. Replace defective caps with original value and make sure replacements are 105 degree for longevity. Common problem, let me know if this helped.
Sam Farrell
Feb 17, 2011 | Proscan 42LA45H 42 in. LCD TV
TV JUST WENT POP NO SOUND AND NO PICTURE
good day hope I can be of help to you...is your TV "dead set" if so try these easy steps to trace the problem.. check the power cord for any burn or cut wires...check for a blown fuse... if you replace the fuse w/ same type and if it still been blown do not try to replace it again.. if this happen you have a defective power supply...let a certified technician now do the troubleshooting...good day...
Feb 13, 2011 | Toshiba 42LX196 42 in. LCD HDTV
My Toshiba 32AV500U - the picture went blank.
This problem usually happens when the lamp runs out, verify how old is your TV, lamps have a life spend of aprox. 3 years, most likely you would have to replace the bulb so your TV can start running again!!
Mar 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
Dec 23, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
