Toshiba SD-V394 DVD Player / VCR Combo
Problem for Toshiba SD-V394 DVD Player / VCR Combo
Water under unit
By novalock on Jan 18, 2008
I had a rain storm outside and the water came in through my outdoor antenna cable and settled at the bottom of the unit which i did not see--I Do have vcr picture and dvd picture--BUT NO sound on dvd or vcr playback--what should i do? Kenneth novalock@mail.com
Solution #1
posted on Feb 14, 2008
Not Rated)
Mergatroid
Rank: Wiz
Rating: 84%, 210 votes
I'm sorry to hear this.
If you're really lucky, and it was just wet while you were first testing it, it will have dried off since then and might work now. However, the odds are better that the problem is not a wet board, but rather a corroded board.
The water must have caused corrosion on the traces and/or components in the audio portion of the circuit board.
First unplugg the unit and all the cables. Use a good light to help you look inside the center of the audio jacks. Can you see any corrosion inside the jack? If yes, roll up a piece of emery cloth small enough to put inside and use it to clean the jack.
If that doesn't work, the unit would have to be taken apart. All the connectors removed. You MAY have to remove the VCR assembly if it is sitting over top of the circuit board. That's not fun.
The object is to remove the entire circuit board so you can put it on a bench or table. You'll need a good light and a magnifying glass.
You have to examine the entire circuit board for patches of rust. Pay particular attention to the bottom of the board as it was closest to the water.
Check the components for corroded leads,
check the ports where they are mounted to the board,
check the wiring harness connectors,
check the general condition of the board and the traces. Any traces that have rusted through will have to be repaired using jumper wire and solder. Rusted components will have to be reattached using solder, or replaced if they are unrepairable. Contaminated harness connectors will have to be resoldered at least, and may need jumper wire to repair traces they connect to. They may also require their pins to be cleaned, and the corrosponding harness may also need its matching connector cleaned. Check the harnesses for broken or rusted through wires and repair accordingly.
That's a lot of work, but it's unlikely you'll need to do all of it.
Once you find the rust, you can concentrate on that area and do a general check of the board after the repair.
If this isn't your cup of tea, time to buy a new one.
Was this helpful?
Yes
No
Popular Solutions for Toshiba SD-V394 DVD Player /
Questions and Unsolved Problems for Toshiba SD-V394 DVD Player /
Do you recommend Toshiba SD-V394 DVD Player / VCR Combo?
Answer
Answer
i need to change the password...forgot the old one. how do i do this??? HELP!!! THANKS KELLY
Answer
what do i do with my dvd i bought from Amazon uk? it says region code error and will not play. it is... (More)
Answer
looking for hack codes for Toshiba VHS DVD SQ PB official name SD v394sc Thanks, Sandra
Answer
my tv has a built in dvd player. The sliding disk holder got stuck and is sticking out and will not... (More)
Answer
One side of the disk drawer has come off it's track and is now stuck open
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
