Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Lamp will not come on after replacement
My lamp went out and I purchased two replacement lamps. When I installed them, neither will come on. The lamp light comes on a steady red which the owners manual says to replace the lamp. I would be surprised if both replacement lamps are bad.
Randy
  • miafixit Jun 06, 2008
    First time my bulb went out, I had a local company come out and fix it. The bulb lasted for about 1 1/2 years. I then ordered from a company which came with the bulb as well as the cage or casing, my husband replaced this one and it last about 6 months. I just ordered a bulb without the cage or casing and it will not come on. When you plug in the television the timer blinks for a while then it goes off, then when you push the power button the timer stays on with a solid green light, then the orange lanp light comes on along with an annoying whining sound. Still no picture
  • Mitsubishi Master
  • 8,617 Answers
Sounds like a ballast problem. Did you change the ballast or just the lamps? You may want to check your ballast, also the air filter, as this will stop your set from powering on.
Posted on Jan 18, 2008
Replace the color wheel
Posted on Jun 10, 2008
I HAVE A SAMSUNG SP46L6HV REAR PROJECTION HD DLP TV AND IT HAD MAKING A NOISE BUT NOT THAT LOUD AND THEN ONE DAY IT WAS ON AS NOMAL AND JUST WENT OFF , MY HUBBY TOOK THE BACK OFF AND SAID THE LAMP WAS...
Before it went out, was the sound like a fan or high pitched in nature?
Lamp can be removed (is is customer replaceable) to see if shattered inside.
I suspect a bad color wheel, which is not hard to replace. See attached photo of color wheel.
Examine lamp and if not shattered do not buy one to try.
I am here to help you for free.
Comment here and I will assist you.
SD TECH
Sep 16, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
My Mitsu 52525 lamp indicator went solid red. I
sounds like the caps on the power board have failed. You can get the V26 DM/Power repair kit from www.tvrepairworld.com which also contains the instructions.
May 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
Mar 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
We have purchase a new lamp bulb. When we
This is a classic example of a bad lamp. I realize that you replaced the lamp but the new one could be defective. Put the old lamp back in if it is available and worked at all before you replaced it. See what the set does then and if the red flashing light goes away. If you can't do that and know positively that the lamp is good then it could be the lamp ballast board. It is available at http://www.encompass.com and is not very hard to replace. Unplug the set, remove the lower back, you should see the board near the lamp. R&R the board, reassemble, and you should be done. If you need more help let me know. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 19, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony projection television lamp replacement...
hello the last light at the bottom of the tv will flash this will tell you the lamp as burn't out i would buy the lamp in the housing it just makes it easyier to install when you do install it make sure
Nov 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp has been replaced but TV wont power up?
If the lamp is a known good one, the next most likely suspects are the lamp ballast/power supply board or a mis-aligned lamp door. There's an interlock switch which opens when the lamp door is removed. Try removing and re-installing the lamp and the door.
Feb 15, 2009 | Zenith E44W46LCD 44" Rear Projection...
Optoma ep 706, lamp lights on,replaced lamp, still not working
moz-screenshot.jpgmoz-screenshot-1.jpghello,
This is an unfortunate incidence and i will send you the serviceable manual of your projector if you can send me your contact email address to my email.Yes ,there are instruction to follow to replace lamps in projector if not you might miss it. First you must confirm that the lamp is OK from the vendors you purchase before anything.
Bye.
anytony2004@yahoo.com
Aniekeme Anthony.
I
Jan 21, 2009 | Optoma EP706 DLP Projector
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
FRONT CORNERING LAMP
I went to a Napa store (Belfair, WA).  They helped me purchase the right lamp and then went out to my car and installed it free of charge!  It took about 15 minutes.  Those guys are great!
Jun 27, 2008 | 2000 Ford Windstar
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
323 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
