Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
KUDIO1ILBS2 KitchenAid Dishwasher, two years old, not heavy usage: control panel is dead, no other power problems in the apartment, the apartment's electical box shows all breakers ok.
  • 447 Answers
These dishwasher have a thermal fuse near the contol panel protecting the heat sensitive computer. Do you use the Sanitize or Anti-bacteria cycles?? If so then these cycles get very hot and could have made the fuse blow. Kitchenaid also had some loose connection problems at the fuse making the fuse heat up due to the electicity and not actual temperature. The new fuse comes as a kit with connectors already attached to the fuse (dont mess with them) and a junction block to splice the wires.
Posted on Jan 18, 2008
KUDS01IL KITCHENAID DISHWASHER ALL CIRCUTS ARE ON BUT DISHWASHER IS DEAD. NO
RESPONSE WHEN TOUCHING CONTROL PANEL BUTTONS.
Posted on Sep 28, 2008
Also make sure the electronics are clean. I cleaned the cobwebs out of mine and things have been good ever since.
Posted on May 04, 2008
6ya staff
SOURCE:
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
Kuds24se dead
HAve you check the power supply to the control panel? you may need to open the panel and check the circuit.
Sep 18, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
I little puff of smoke came from my Kitchen Aid Dishwasher Model 8531654 and now is not working. The lights are on but it never cycles through.
Sounds like the motor when ka-fooeey! Have a technician check the motor with a volt-ohm-meter to make sure that that's the problem.
Feb 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Normal cycle leave dishes half clean. Heavy cycle
in the bottom of the machine, under the bottom rack, is a screen looking piece. twist or just pull up, should be able to clean that then replace.
Aug 08, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwasher stopped working. Suspect electronics issue.
An expert from another site says it's a faulty control panel and may need new actuators.
Jan 31, 2009 | Dishwashers
Dishwasher stopped working during rinsing cycle.
1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse with wiring harness supplied with it.
Good luck
Vlad
First Choice Appliance
Jan 05, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher lights are all flashing
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Nov 23, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Sep 21, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
1,296 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
