Question about LG CHOCOLATE VX8500 Cellular Phone
My LG Chocolate VX8550 wont recognize micro sd card
I have tried to format a Sandisk 2.0 GB micro sd card to my LG Chocolate VX8550. The phone does not appear to even read or recognize that there is a card. I have used the included adapter and my computer recognizes and utilizes the card--any suggestions beyond maybe the phone is broken?
  • 13 more comments
  • Anonymous Feb 15, 2008
    I simply put the micro card in my phone FIRST. Then I took it out put it into the SD adapter, inserted it into my computer and transferred songs to the SD card from my list of music i have on my computer already. It worked quick simple and didn't require the CD or USB adapter from the phone company. Piece of cake.
    Good luck.
  • Anonymous Feb 17, 2008
    My palylist shows up on my card through my PC but nothing on my phone.. I don't know what I am doing wrong.
  • emmanuel07 Feb 18, 2008
    I try to put some music into my LG chocolate vx8550 but I can't. It seems like the CD I received with the USB doesn't work. Is there any software I can download instead of the CD. I also have an us card but I don't where I should put on my computer.( it's not a laptop.)
  • yungsmackz Feb 22, 2008
    My computer, doesn't recogzine my micro sd chip for my Nokia 5200 when pluged into my computer
  • Fansh24 Jun 06, 2008
    Exactly the same problem. Apparently the default code is "0000" or "9999". neither works, nor my account code. So how are we supposed to format the card so it is usable with this Chocolate?
  • Anonymous Jun 22, 2008
    my computer wont reconize my phone or let me put music on it
  • tlalic Jun 30, 2008
    I put my sd card in the computer and all my music files are there when i put it in my phone it says there is nothing on there...I don't get what I need to do to for it to recognize it
  • Anonymous Nov 20, 2008
    I have a vx8560 (Chocolate 3) and it doesn't recognize my memory card. The memory card is a Kingston 2GB MicroSD model 30878-001-A01LF.
    the phone gives me a "Card Not Inserted" message.
    I can use the card just fine with my pc.
  • Anonymous Nov 28, 2008
  • Gillian Zyland Dec 11, 2008
    I have used the SD micro card before transfer mp3 songs and podcasts from my Macbook to my LG Chocolate 3 phone. But now I have a problem. I took off old podcasts I was done listening to by deleting them from the SD card when it was hooked up to the USB adapter inserted into my Macbook port, and then I added new songs and podcasts to the card. But when I put the card into the phone, suddenly the phone said I had NO songs and NO podcasts. Every category shows up as empty -- under "songs", "genres", "artists", etc., it just says "Add Songs to Play Music", as if there's nothing there at all. ARGH. My computer says that there's tons of stuff on the card, but none of it shows up on the phone now. What do I do????
  • angelbunnie Jan 03, 2009
    I tried doing what I read above about putting in the last 4 digits of my phone number. It accepted them and asked "format card?" I said YES, it said "formatting", then after about 30 sec it said FAILED. Whats going on now? Anyone can help?
  • swaran_21 Feb 03, 2009
    iam having problem with LG chocolate for transferring data
  • Anonymous Apr 18, 2009
    my micro sd car cant be recognized help me
  • babiliflys Apr 20, 2009
    My phone doesn't even recognize that I have the card in there... what does that mean? I know I put it in right because there's no other possible way for it to fit and I know I have stuff on it but the phone can't recognize it. Help!
  • Anonymous Mar 13, 2014
    My micro SD card slot is broken and I don't know how to fix it
Here are the steps I took:
  1. Insert the micro sd card with the metal plates facing you (that took me a second). Don't worry about the little push you have to give.
  2. Go to the Settings & Tools option in the Menu.
  3. Select *. Memory
  4. Selct 3. Card Memory
  5. Select Options while the bar is on "1. Memory Usage". The only option available to me was 1. Format and select that.
  6. It will ask for the phone lock code-if you have never set it IT IS THE LAST 4 DIGITS OF YOUR TELEPHONE NUMBER.
  7. The phone will format the card and put the file folders on it.
  8. Use the adaptor USB reader or whatever you have to connect it to the computer. Copy songs to the my_music folder.
for mp3 as ringtones:
  1. You should select the part of the song you like, and can add effects with this:
  2. To set it as a ringtone, send it as an attachments to you It must be small to go through, around 30 seconds.
  3. You will get a text message, and select options. Select Save As Ringtone.
Posted on Oct 17, 2008
Um.. Im having the same problem as these other people i guess..i put the card on my pc and it recognizes the music i allready put on there.. and when i put it in my phone it doesnt show that there is anything on the card...
Posted on Nov 17, 2008
When you put your adapter and sd into your computer, drag music files onto the my_music folder not the My Music folder. there is a difference. >.<
Posted on Jun 23, 2008
Is the card all the way in the adapter? I had that problem and once I realized it wasn't fully in the adapter it worked fine!
Posted on Feb 06, 2008
I'm having problems with my microSD card. I inserted the card into LG vx8500 phone but' it doesn't work... music shows on the card when I put it in the computer; but doesn't read on my phone... it says list empty; but when I take out the microSD card it says micro card is out' so, I know there's music on my card ; but it's not showing; what the heck am I gonna do! :)lol.... I'm fustrated & I'm almost giving up on this phone card thingy... PLEASE , PLEASE someone help me.... Lots of ALOHA,Camille
Posted on May 24, 2008
Put your Micro chip into the Chocolate
Take it out and connect it to your computer
You will see that the phone automatically saved folders such as "my_music"
Save your files into its folder
Put it back into the phone
(I'm 12 and I found that out)
Posted on Jan 09, 2009
I had the same problem and managed to fix it eventually. Turns out that when you try to turn on your phone MP3 player, it is looking in the wrong internal memory - so you get "list empty"! So you just need to move the files to the correct phone memory.
1) Plug in the phone to your PC using the USB cable.
2) Go to your PC and click on My Computer. You should see your phone listed as a drive denoted by a letter e.g. J, K , L etc. 3) Double click on the drive and you will see a folder called My Media follwed by a list of all your MP3 files.
4) Cut all the MP3 files to your clipboard.
5) Double click on the My Media folder, then on the Music folder.
6) Paste the MP3 files into the Music folder.
7) Disconnect the phone from the PC - and hopefullly job done!
Posted on Jan 10, 2009
I put my card into the phone and there are songs on the phone that don't play and I can't delete them!!
And when I put the card in my computer, the card does't show the those songs so I can't delete them using the computer either!! They are labled like JJ on my phone and it's wierd!!! HELP!
Posted on Oct 16, 2008
1) The microSD card is inserted into a slot on the right side of the phone, approximately at the level of the top of the display screen. It has a cover which lifts off in the same way as the place where you plug in the charger. The microSD chip goes in with the contacts facing toward you (as you face the phone) and will only go in one way. Press it in gently until it latches in place. To remove it, press on it again and it will unlatch and pop out just far enough for you to remove it.
2) When viewed from your computer, the Chocolate VX8550 microSD should show four directories (folders) called my_pix, my_flix, my_music, and my_sounds. Music, in mp3 format, must be saved in the my_music folder. If you save it anywhere else, the phone will not "see" it.
When you insert the microSD card and power on the phone, the phone will create an index of the mp3 files using the information embedded in the mp3 files (artist, album, genre, song).
Please note that the phone also has its own internal memory which is separate from the microSD card. It is possible to move files from the card to the phone and vice versa, but when you do so, the file is moved, not copied.
Posted on Aug 20, 2008
Uhh,,, I dont even know where I put the sd microchip!
Posted on Apr 28, 2008
I cant find where i can put micro sd card
Posted on Feb 04, 2008
You have to put your MicroSD card in the phone and then take it out once you do that put it in your computer and it should be already for formating, you should see files on the card.
Posted on Jan 20, 2008
LG800G wont recognize 4gb micro sd card
The LG800G works with microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot, it's electronically incompatible and will not work with this phone. You need to use microSD cards, 2GB and smaller.
Oct 18, 2012 | LG 800g TripMinutes Touch Screen tracfone...
Cannot copy anything to Memory card in LG Viewty
reformat your card through your pc. don't go for quick format. if it doesn't works after that also then get a software 4 low level formatting. if then also it doesn't works ask me again.
kindly rate my solution.
Jun 25, 2009 | LG KU990 Viewty
How do I get games onto my LG-VX8550 (Chocolate 2)?
if your phone is a JAVA applicaion supporter then try with jar
Jun 02, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Try using a usb card reader.. just put your sd card in appropriate card reader. and insert that card reader in your pc transfer your file in your sd card.. and install in your mobile..
have fun
May 19, 2009 | LG VX8550 Cellular Phone
LG Cookie Won't Recognise Memory Card
it will need to be smaller then 8gb...... also micro SD......... NOT micro SDHD also need to format it using the phone (check user guide for info on how to do this)
hope this works for you .....good luck
Apr 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Lg kp 500 wont recognise sandisk micro sd!!! aghhhhh!!!
Some memory card wont be recognized by some phones or pc's. I also bought a sandisk card before and just found out (through reading online forums) that some don't actually work.
Feb 22, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Trouble in formatting my SD micro sd for my lg chocolate cellpfon
use some other card reader for the purpose and format it from there.
Feb 14, 2009 | SanDisk 2GB microSD Memory Card
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Jul 02, 2008 | SanDisk 2GB microSD Memory Card
Coping pictures from computer to mocro sd memory card
Please check the format of the card it has been formatted with. Try formatting it on the computer and then use it to upload and download pictures on the computer as well as your phone.
Let me know!
Dec 25, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
LG CHOCOLATE VX8500 Cellular Phone Logo
8,472 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
