Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Machine is Whining
My machine is making a whining noise (sounds like it's coming from the middle top portion. You'll think it's about to give up & quit & the unusual sound goes away for a bit.
    Problem Solver:
How do you get the flywheel off to check for any thread?
Posted on Jan 20, 2008
    Scholar:
  • 110 Answers
Any unusual sounds should be checked out by your dealer to prevent serious damage. However, first check the flywheel, on the top right side of the machine, for any thread that were caught between the flywheel and casing, causing the motor to work harder. If not, take it to your dealer.
Posted on Jan 18, 2008
Singer Heavy Duty 110 making whining/screeching noise.
If you cleaned and oiled according to the owner's manual, then that probably isn't the issue. Suggest consulting the owner's manual, troubleshooting section. Machine could also be out of time.
Some reviews on this machine are not great:
Amazon com Customer Reviews SINGER HD 110 Heavy Duty Model Sewing Machine
If you've had this machine for seven years and haven't had problems until now, it may be a good time to think about replacing it.
Oct 04, 2015 | Singer Sewing Machines
Sound from only one side
Sounds like your belts might need adjusting, and that's a job for a technician.
Jun 18, 2014 | Singer Sewing Machines
Machine stopped sewing even though it sounds like its running
I would suggest taking the machine to be checked to see if the machine has a broken part or jumped time.
Nov 26, 2013 | Necchi 3620 Quilter Mechanical Sewing...
Brother sewing machine noise
Sound like the whole unit needs a good cleaning.
My rule is "if it moves give it a lube", be careful not to get oil on electric boards or in the motor. What is the make and model of your machine. I will try to help you more.
Feb 26, 2013 | Sewing Machines
The handwheel is extremely hard to turn. it will turn using the foot pedal but it makes a whining noise. could it be the belt?
Look on the back of the machine there is usually a tension dial. Try adjusting that. I f that does't work your manual lists instructions for cleaning and oiling a little bit of oil in the right place works wonders or on the oher hand a little thread in the wrong place will stop an electric motor.
Feb 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
The bobbin thread nested underneath, tried to stop
Have you turned it back on once the machine has cooled down? If you have, and it still makes noise and won't stitch then I think the motor is damaged and you need to take it for repair. Does it do ordinary sewing or is the motor completely uncooperative?
Meantime, take the bobbin assembly apart and clean it out - ask for more instructions if you don't know how to do this. Be sure both the top thread and bobbin threads are threaded correctly and clicked into their respective tensions. Did you "park" the embroidery unit before turning the machine off? You need to do this, if the machine will do it that is.
You will need to take the machine in to be checked even if you do get it working. Any major problem with nesting - did you break needles too? - almost certainly will have put your needle assembly out - it will need re-centering.
Dec 15, 2009 | Husqvarna Designer I
Singer 7469 Confidence sewing machine instruction manual I cannot figure out how to do just a straight stitch The machine is just whining... and not doing anything.
Make sure that the right large dial (which is the drive wheel for the motor) is engaged. You might have it set for winding a bobbin and the needle will not go down unless you have the right wheel pushed in.
Nov 10, 2009 | Sewing Machines
Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Feb 12, 2009 | Janome Memory Craft 9000 Computerized...
Pfaff 2029 sewing machine.
No the sounds are not normal,
I would suggest you have the machine looked at by a sewing machine tech.
I have never come across this problem before and would need to look at the machine before making a diagnosis.
Sorry to be of little help but it would be unfair to give bad advice.
Mar 31, 2008 | Sewing Machines
Whining also
ASAP....please it might just need service....how old is the machine?
Jan 20, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
184 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
