Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water Leaking The back part of the refridgerator inside where the cold air comes out is leaking water and the back inside wall is wet?
  • 2 more comments
  • eltgolf Apr 06, 2008
    I have the same problem and water is accumulating underneath the crispers at the bottom of the fridge. My fridge is a Whirlpool Top-Mount Refrigerator, Model Number ET8MTMXKQ0
    Any suggestion would really help and a how to, to get rid of the problems.
    Thanks in advance
  • AKH00 May 05, 2008
    "Model # ET19DKXEN01 Serial # EF1021328 Whirlpool Designerstyle 3/'96" ... Had the same problem with the drainage leaking from the freezer and drain pipe being froze... i unplugged the fridge and let it thaw out for 24hrs ... when i cleaned it to put it back together i noticed that the back wall inside the fridge (not the freezer) had a small bulge and when pushed you can hear water inside the back wall of the fridge ...is there a solution to this, some way to drain the water ... i called whirlpool costumer service and they told me this was not a serviceable problem
  • Lynn223 May 28, 2008
    I have Model ET21PK and it is leaking from the freezer inside the refrigerator under the crisper's. How can I fix this?
  • mjcl63 Jun 27, 2008
    Whirlpool model # ET18PKX6H0 waterbuilding up on bottom of fridge under the crisper drawers. seems to be dripping out of freezer on the inside of fridge. it's a top freezer with no ice maker. very irritating we're thinking of getting a new refrigerator. it's been cleaned, defrosted, moved from wall all recommendations have been followed. I thought whirlpool was suppose to be the best??????
HELP WITH ODOR COMING FROM MY FRIDGE
Posted on May 03, 2008
  • 51 Answers
The defrost drain is clogged up. I can't say much more because you didn't supply the model #
This may be a drip catch that you can get to from inside the refer or it may be the big tube on the backside of the box.
You may have to take the freezer apart and use a hair dryer to thaw out the ice.
Model numbers are important!
Posted on Jan 18, 2008
I have 1998 cadillac seville. Added coolant, but air-conditioner didnt come on. Cleared ACM code and air came on. Next day hot water was leaking on foot pedal while I was driving!
hi is water or coolant that is leaking .if its coolant leaking your heater core
needs to be replaced .put if its water leaking all you have is clogged water
drain . to fix open hood on the passenger side fire wall is a small "L" shaped hose
that comes out of the fire wall and not connected too anything clear hose
BEFORE PUTTING HANDS BY FIRE WALL &ENGINE MAKE SHORE
ENGINE IS OFF AND COLD . IF NOT YOU CAN GET INJURED
Jun 13, 2011 | Cadillac Seville Cars & Trucks
Water drips inside our refridgerator . it comes from a point where the cold air comes in from the back wall
Take a large clear bowl half full with water and place it on the top center of the unit. This will help you to level the unit on all axises.This is probably your situation because during the defrost cycle the water that remains is supposed to go through a small hose and be evaporated by the warm coils in the rear.
Sep 13, 2009 | Maytag PTB1954GR Top Freezer Refrigerator
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
WATER LEAKING FROM INSIDE BACK OF REFRIDGERATOR SAMSUNG 267LASH
The frigerator has a drip pan it may need to be empty. Check the water line for leaks going into freezer.
Apr 11, 2009 | Refrigerators
Air Conditioner leaking water
there is a drain that comes out the wall to the outside find it and **** it out with a good wet dry shop vac.
Oct 19, 2008 | Sanyo 09KHS51 Ductless Mini Split Air...
You should fine a drain line just below the freezer level in the back. The drain line is more than likely plugged. Check the loop seal down by the drain pan under the back of the refrigerator. It may be restricted at that point. It may require a complete defrost of the freezer to clear the ice formed in the drain from a back-up.
May 28, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leak
What's happening is when the fridge goes into defrost water goes thru the drain and is seeping into the crack by the damper which will run into the fridge section.  Why?  The drain doesn't come down far enough for all the water to go down the drain tube.  Frigidaire has a new drain that is longer and will prevent this problem.
Oct 22, 2007 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
255 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
