Back to:
Tags:
OKI C5150n Led Printer
Sensor error
posted by Kristi Bash on Jan 18, 2008
Every time i go to print it says there is a sensor error. I have to lift the top and wipe down the black ridges on the top inside cover. Then it will work. I ahve followed the directions in the manual which says i need to push the lock lever back and they are as far back as they can go. Any suggestions.
Comment by Kristi Bash, posted on Jan 20, 2008
I have changed the toner and ink cartridges several times and it has just started doing this. Thanks
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Soulvisitor
Rank:Guru Guru
Rating: 88%, 1551 votes
Change the toner with a new oki one, if that fails change the drum too
Sensor error should inicate colour too ie K sensor error is black
Comment by Soulvisitor, posted on Jan 20, 2008
With Genuine oki ones?
No ink in this model it is toner
Change the drum unit.
Hi again just had cust with same issue, if you look at side of toner unit(handle side) there is a little rectangle window that goes empty or black when toner is out, it is silver when has toner, this lines up with a sensor that looks at window, clean this area and ensure window is silver.
Rating Locked! (?) Kristi Bash has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on sensor error:
I don't want to Accept this solution
Can you Help with these Printers problems?
OKI c5150 prints yellow shadow above graphics, text prints...
One day, my Oki c5150n began printing void streaks on side...
why is the attention light lit. all of a sudden, we can't...
My OKI C5150 printer recently started printing blue...
My printer is printing the color graphic on one side of...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
