Question about HP Pavilion dv6000z Notebook
Hp Pavillion laptop freezes when I install secondary memory
I purchased 512 addit'l memory for the laptop and installed it in the slot on the bottom of the laptop. After that it would not boot, get to the post screen and stop, and ocasoinaly it would boot but freeze after about 3 minutes. If I boot to Diagnostic CD it would freeze but take a longer time to do so.
Removed the chip and left it out. booted and ran fine. Replaced origional 256 chip and sill freezes. Ran memory test and all passed. Memory is correct for the systemas well.
Finally I put the new 512 stick in the primary slot under the key board and it runs well. Again, I put one of the origional 256 in the secondary slot, again it started to freeze. switched chips with the other 256 chip and same result.
There are no Bios settings that can be changed; this board has a basic bios setup. cannot see it being a heat issue because it hapens when the systen first starts i the morning and when it is warmed up.
Ive done as much research on this problem but still fail to find any solutions.
Hp presario zv6000
XP Home edition
if you need more info let me know
  • 1 more comment
  • bdsext Jan 19, 2008
    That has been my experience as well, but I get the same freezes in the system when I put the two origional 256 sticks back in the machine in their respective slots. It is almost as if the seconday slot that is on the bottom of the machine is causing problems that previously weren't there. Coud over heating of the system perminatly effect this slot , yet allow the computer to still function fully on the primary memory?
  • bdsext Jan 21, 2008
    laptop only has two slots.. so putting three chips at once is not a issue. The TWO ORIGINAL 256 chips were placed in the slots and I encountered the problem with the freezes. There have been numerous posts on the web about this problem from other people with no solution.
    I have for time being placed the 512 in the primary slot and all is well but I tested a 1gig chip and it will not run on this laptop even though HP says it will take a total of 2 gigs of RAM.
    Still hoping for another answer. By the way, about how much would it cost to check a Motherboard ?
  • Maestro loco Feb 08, 2008
    My HP pavilion zv5000 had 256MB cards in both primary and secondary memory slots (total of 512MB RAM). Bought 2 Kingston 1GB cards as replacements to upgrade to 2GB, which HP says is capacity of this laptop. Both Kingston cards are compatible with this model according to HP. With both cards installed (primary under keyboard and secondary on bottom of machine), system either refuses to boot or freezes at desktop. Can get to desktop in Safe Mode. System configuration shows that 2GB of memory are recognized. When secondary 1GB card was replaced with original 256MB card, computer works fine (system config shows 1.2GB of RAM). I am typing this on the machine now. I assumed the Kingston card in the secondary was defective, so I returned that card and am awaiting a replacement. Obviously, there is nothing wrong with the secondary slot, as the 256MB card works fine.
  • 1,226 Answers
You may not put all together the 256 and 512, the system encountered error when two memory are not equal size and not equal brand.
Either you select 2 units 256 memory or either 2 units 512. or use only 1 unit 512 memory so that no freezes will happen.
Posted on Jan 18, 2008
  • Emelio Navaja
    Emelio Navaja Jan 21, 2008
    Ok you should install only one memory in the primary slot . Only install 1 512 in the primary, coz maybe the other slot is have damage. you have option on that except replacing the Mboard of the system. but if the primary slot working on 1 512 so why not use it for the mean time.
  • Emelio Navaja
    Emelio Navaja Jan 22, 2008
    That is the problem when the laprop motherboard in trouble coz it hard to find a replacement on it. That is why costing on the laptop check mainboard error i could not calculate.
I have compaq presario V3070TU with 512mb ddr2 RAM. i tried to upgrade to 2 gb RAM into one bottom slot (not 2 numbers of 1GB), but 2gb RAM is not working(display is not UP). only 1gb RAM is working....
I could not figure out the relationship of the hard disk with the memory.
try change the memory dimms put 512 in bottom and 1gb in the other possition and see what amount of ram you get
Aug 02, 2013 | HP Pavilion ze4365us Notebook
Installedmemory now pavillion ze4610 just beeps and shuts down.
Make sure your battery is removed, unplug, reseat memory mods, make sure they are inserted fully. I assumed the 512MB are used? New? There is no reason , that I can come up with, they should not work? I have upgraded many memory mods without incident.
Dec 03, 2012 | Computers & Internet
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
I just got a 1 gb ram memory from you for my pavillion zv6000 laptop. I opened the back to install it and there is a ram in there already. I thought I was just adding memory. help
section 5.6 gives memory specs, earlier in the manual it only refers to one memory slot. You have to pull the existing one.
I always tell my customers what the max memory you can install, and what will have to be removed. Apparently someone else didn't.
You might want to download that pdf. It's the full maintenance manual on your machine.
Jan 08, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
How to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
Oct 04, 2009 | Compaq Armada E500 Notebook
How to install additional memory for Sony laptop
Here is how to add or replace memory for Vaio T300 series laptop.
Scroll to page 122 for slot on the bottom of the laptop,
Scroll to page 125 for slot underneath the keyboard.
Mar 28, 2009 | Sony VAIO VGN-T350P/T Notebook
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
How to upgrade memory for compaq evo n610c?
The maximum amount of memory you can install is 1GB 266 Mhz SDRAM DDR SDRAM (512 -MB in slots 1 and 2)
The motherboard will not handle any amounts larger.
It is suggested that you use Compaq branded memory to ensure compatibility with what you have. Otherwise, pick two chips that are the same.
This site will show you where to find the location of the memory.
The slots are below the keyboard to the rightr of the track pad. THe "Tabs" that hold the lid down can be seen if you look at the bottom left of the keyboard area. You need a flathead screwdriver size small to remove the lid.
Apr 18, 2008 | Computers & Internet
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
290 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
