Question about Sony STR-DE845 Receiver
STR-DE945 stuck in auto protect mode?. I'm pretty sure it is the output capacitors but I do not Know where they are located to change them.
  • 1 more comment
  • cozmo Jan 18, 2008
    could you send me a picture or schematic showing output transistors?
  • cozmo Jan 23, 2008
    there are 5 ,how could all 5 go out at the same time?
  • avdg Dec 23, 2008
    Sony STR-DE845 5.1 Channels Receiver is stuck in protect mode, I found a set of outputs bad and replaced them, prior it would only blow the main output fuses, with no operation. Can I get a skematic of the unit to diagnose further. Can someone get it for me?
First of all my STR-DE845 started having the protector problem about 6 months ago and I bought this receiver back in 2001. This is what I found wrong with mine. After searching online I found a service manual for the receiver, this came in handy when diagnosing the problem. The first obvious thing was discoloration of the board around the IC 501, 601, and 701 Op-amps. When looking at the receiver from the front these are the three vertical NEC ICs to the right of the main amplifiers. Even with no load these amps get very warm. Sony failed to add any heat sink to these ICs so eventually they can de-solder themselves, specifically the 701 IC which is the one closest to the back of the unit. With mine I was able to slightly push the 701 more vertical, since it was leaning, and I believe it has helped it make a better contact. The protector circuit will kick in if it senses the Op-amps are shorted or not making contact. The best solution is to add some copper heat sink to these ICs, they already have screw slots for a heat sink. If they ever fail you will have to get new op-amps and re-solder them to the board. Hope this helps.
Posted on Apr 18, 2011
  • Arthur Dent
    Arthur Dent Feb 07, 2015
    Thank you for posting this, it solved my problem too! In my case it was IC601 - I just pushed it over a bit and the receiver started working. I'll leave it and see how long it works; if it fails soon I'll remove the main and rear amp boards and re-solder the ICs. I found the service manual athttp://www.epanorama.net/sff/Sony/Audio/...
    Problem Solver:
  • 5 Answers
I had a mechanical problem with the relay on the 1st power supply board. The relay right next to the small transformer. The blac cover for the relay just comes right off. Make sure that the little black plastic piece is still in position (you'll see what I mean when you open it.) and check the contacts on the relay.
Posted on Jan 24, 2009
    New Friend:
See my response to kj4bhp above. The service manual is currently available at this link: http://www.epanorama.net/sff/Sony/Audio/STR-DE835,%20DE935.pdf
Posted on Feb 07, 2015
    Sergeant:
  • 395 Answers
Determin if the speakers are at fault first. un-hook them and turn on the unit if it stays on one of the speakers is bad. if it remains in protect, the output transistors are shorted. there are a pair for each output. they are located on the large heatsink in the center of the unit.
Posted on Jan 18, 2008
  • Robert Johnson Jan 23, 2008
    5 channel suround means 5 output pairs. check for the ones that are shorted, use an ohm meter to test them. only one pair may be at fault, if the over current is detected by the microprocesor the system goes into protection. in other words if there is a short on only one pair, the system detects this as an over current draw and shuts down the ON command. if you use the reciever with only 2 speakers (front left/right) than check those pairs. that at least narrows it down. I'm still tring to fine a link for a service manual for you.
Sony str-de945 s.1 rear speakers not working
rear speakers may only work once you have a 5.1 or DTS signal source connected
Apr 20, 2014 | Sony STR-DE945 Receiver
Can I get digital output through my STR-DE945,
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE945-Receivers-manual/id/387dj982/t/2/
The far left optical connector on the back is an output.
Feb 21, 2011 | Sony STR-DE945 Receiver
Please tell me how to remove the fan from the receiver it has stopped working causing the unit to go into a Protect-Fan mode thanx for any help John
hello the reason the fan has stop working may be down to the output transistor shorted out or a swelled capacitor
regards
shaun
Sep 12, 2010 | Sony STR-DE945 Receiver
STR-DE845 Stuck in Demo mode, tried the power and ...
To get the STR-DE845 ( or STR-DE945 ) out of DEMO MODE - Turn unit on and HOLD POWER BUTTON FOR A FEW SECONDS ...Turn unit off and when you turn it on again it should be reset ...It worked for me.
( Note : You may need to do this procedure before it goes into its actual demonstration of features ... Press and hold the power button immediately when it initially starts scrolling it's DEMONSTRATION MODE message . )
May 12, 2010 | Audio Players & Recorders
How to verify which transistor is creating protection mode?
Take your ohm meter and measure the outputs one by one. with the power unplugged and the main board flipped to access this circuit. If they all check the same , no shorts , then You may have a preamp driver failure. Larry's Electronics ledstiles@hotmail,com
Apr 25, 2010 | Sony STR-DE945 Receiver
Have a str-de 945,unit was working,sound stopped,still powers up.Replaced 2, 8 a fuses,blew again,nothing was connected to the unit.The heavy power supply unit in the front seems to have a hard orange...
Chances are you have shorted output transistors,check with ohm meter across all 3 legs,there should be no shorts if good.. cost on average around 150.00
Apr 16, 2010 | Sony STR-DE945 Receiver
STR-DE197 Continuous Auto-Protect
Probably dry joint on an output/regulator chip or a failed output ic.
Jun 29, 2017 | Sony STR-DE197 Receiver
Sony STR-DE945-Component Set Up
billr, Go to http://www.retrevo.com/search?q=Sony+STR-DE845&terms=review+manual You should have a pdf of the 845/945 manual waiting!
Mar 11, 2007 | Sony STR-DE945 Receiver
Sony STR-DE845 Receiver Logo
1,622 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
